1978 - 1996 Big Bronco
does anyone know
Old Dec 13, 2015 | 12:55 PM
JayderAK's Avatar
JayderAK
does anyone know
what the part number is or where i can find the pulley/bracket that replaces my air pump and i can still use the same belt?
for a 93' custom
Old Dec 15, 2015 | 01:58 PM
g_k50's Avatar
g_k50
9B447, go to fordparts, select your year, make, model, search the catalog for air pump, the pulley number comes up and there's a diagram to look at, select other parts needed for more information. It asks for 5.0L or 5.8L, whatever that means
Bracket is 10A313
Old Dec 22, 2015 | 05:05 PM
rla2005's Avatar
rla2005
9B447 and 10A313 are generic base part numbers. Searching on 9B447 will yield thousands of hits since it's a generic base part number for a pulley. In order to locate the correct one you will need the prefix and suffix as well.
Jeg's carries an aftermarket pulley and bracket for Mustangs. It also fits a Bronco to the best of my knowledge.
Old Dec 22, 2015 | 06:50 PM
FourXFord2's Avatar
FourXFord2
I have used the Ford Racing smog pump eliminator kit from Summit Racing on 2 of my broncos now. I think I needed a different belt though. I transferred the kit from the 5.0L to the 5.8L with no trouble.
Old Dec 30, 2015 | 09:18 PM
Deadsquiggles's Avatar
Deadsquiggles
What does removing or bypassing the smog pump do for the truck anyway? And does it make it throw codes?
Old Dec 31, 2015 | 05:58 AM
rla2005's Avatar
rla2005
The air pump is there to inject air into the converter to shorten the warmup time. It supposedly does this at other times as well.
You can remove it and the associated tubing, valves and vacuum lines. To keep the Check Engine Light off you need to leave the TAB and TAD solenoids electrically connected. Be aware you will fail a few KOER codes but this will not trigger a Check Engine Light.
If you run a modern 3-way converter the air pump is not required.
Old Jan 1, 2016 | 07:32 PM
FourXFord2's Avatar
FourXFord2
The tube at the back side of the heads can be removed and pugged with a 5/8"X 3/4" long coarse thread bolt. Leave the TAB and TAD solenoids for the ECM. The down tube to the CAT can be removed and plugged then as well. It cleans up the engine bay and unless it has to pass emissions you won't miss it.
alanber
Oct 4, 2018 09:46 AM
OldFords
Jul 13, 2014 05:22 PM
BurnerDoc
Jan 26, 2014 03:01 AM
Pete Kildow
Large Truck
Sep 27, 2013 04:46 PM
ferguson777
Jul 22, 2005 08:44 AM
