Half throttle only
Old Dec 13, 2015 | 08:35 AM
KBOFVA's Avatar
KBOFVA
Question Half throttle only
yesterday it was running fine today only half throttle, going up a hill no power throttle push 1\2 down let off the throttle engine smooths out and starts picking up speed
EGR stuck????
CAC boots look good do not hear any leaks on the tubes
no smoke
ICP 675 at idle full temp, cold 1200
OEM filters with OEM caps
ficm 48.5 to 47.5
can hear the turbo spool up
oil temp less than 10 dec difference with water temp
no code showing up
141,000 2003 F-350 dually
Old Dec 13, 2015 | 11:46 AM
87crewdually's Avatar
87crewdually
What is the boost reading when this problem occurs?
KOEO what are your readings for map, & ebp. They should be the same.
Old Dec 13, 2015 | 12:00 PM
KBOFVA's Avatar
KBOFVA
a round 8 to 10. I will check the MAP and EBP
Old Dec 13, 2015 | 12:16 PM
run6.0run's Avatar
run6.0run
Any black smoke??
Old Dec 13, 2015 | 01:22 PM
KBOFVA's Avatar
KBOFVA
no smoke at all
Old Dec 13, 2015 | 04:07 PM
78fordman's Avatar
78fordman
Watch icp and ipr when past 1/2 throttle, possible hpop issue. Post max achieved icp at running temp.
Old Dec 13, 2015 | 05:28 PM
KBOFVA's Avatar
KBOFVA
ok I was able to get back to the truck to check the MAP and EBP. MAP is 14.0 but the EBP is 0.0 looks like it is plugged or bad I will be able to tear into it tomorrow night, Will update it than.
78fordman it was making around 1800 to 2000 psi before it drop on it's nose
Old Dec 13, 2015 | 05:33 PM
87crewdually
EBP should read the same, 14 or right around there. Did you try driving it with it inplugged?
What does it read @ idle?
Old Dec 13, 2015 | 05:47 PM
KBOFVA's Avatar
KBOFVA
I am getting nothing 0.0 on the EBP was not able to drive it tonight.
Old Dec 13, 2015 | 08:03 PM
87crewdually
Remove it and make sure it's clean. Also use weed wacker trim line and carb cleaner to clean the tube fully. Also check the harness for chafes and check the plug.
Old Dec 14, 2015 | 08:45 PM
KBOFVA's Avatar
KBOFVA
Thanks did not get it tonight been raining
Old Dec 15, 2015 | 08:25 PM
KBOFVA's Avatar
KBOFVA
Update removed the EBP line and found it was not blocked going to get a sensor from ford tomorrow if they have it in stock. can the old one be checked easily
Old Dec 15, 2015 | 08:26 PM
KBOFVA's Avatar
KBOFVA
going to go over the whole harness this Friday should be off
Old Dec 23, 2015 | 01:33 PM
KBOFVA's Avatar
KBOFVA
Update after checking over the harness and replacing the EBP sensor still have the issue took it for a long drive with my buddy watching the tablet found the HPOP was fluctuating. Cleaned the IPR and replaced the Oil Pressure unit beside the IPR (leaking oil out of the connector) no change.
Does it sound like the HPOP seals bad? or the whole pump. This one does have the early 03 round pump
Old Dec 23, 2015 | 01:34 PM
KBOFVA's Avatar
KBOFVA
if the pump is bad which is the best one the OEM or aftermarket
jtyler1694
Feb 26, 2014 06:27 AM
nrichter1984
Apr 22, 2012 10:40 AM
Risk176
Feb 17, 2011 06:31 PM
hittman1422
Jan 3, 2010 06:08 PM
jeffnwm
Mar 15, 2009 08:51 PM
