low voltage at FSS power
Old 12-12-2015, 10:13 PM
jonathanpatr's Avatar
jonathanpatr
jonathanpatr is offline
Any help on whether to worry about this issue with a new ip. I just replaced the ip and realized it was the FSS that was bad. I checked the voltage and it fluctuated between 10.5 and 12V. will that damage the solenoid over time? any help on how to remedy the issue? I did bring 12V to the old FSS and the solenoid did not work. new one delivers a solid click and the ip is running fine.
j
Old 12-13-2015, 07:24 AM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
If at idle, i assume its nothing less trivial than the alternating kicking in and out, and a low reading voltage meter. The fluctuation shouldnt hurt it that i know of. At one point i remember reading that the FSS only requires about 4.5v to function.
Old 12-13-2015, 08:48 AM
jonathanpatr
FSS voltage
Thanks for the insight, I was looking for the service bulletin that describes the shutoffs but couldn't find them. too bad I replaced the whole thing just for the solenoid..
j
Old 12-13-2015, 05:17 PM
irhunter's Avatar
irhunter
irhunter is offline
I don't think it will be an issue for the FSS either. But, I would check some other circuits...are you getting the same voltage variance elsewhere?
brianmoody35
09-29-2016 02:24 PM
Radi
01-30-2015 01:35 PM
drs1963
08-20-2012 09:28 PM
jayhawk714
08-23-2011 11:24 AM
spider007bm
12-22-2004 02:13 AM
Quick Reply: low voltage at FSS power
