Brake problem
Old Dec 12, 2015 | 09:14 PM
Madpark72's Avatar
Madpark72
Brake problem
I have replaced all the drum brakes on a 1967 F100 I bought about a year ago. It had been sitting 5-7 years since it last ran. I now have it running. I can't get the brake fluid to come through the wheel seals. Help please
Old Dec 12, 2015 | 09:32 PM
ultraranger's Avatar
ultraranger
Welcome to the FTE Bumpside forum.
What all did you replace and do you have manual brakes or, do you have a power brake booster?
Old Dec 12, 2015 | 09:36 PM
72Truckin's Avatar
72Truckin
did the brakes bleed fine? How is the health of the brake lines?
Old Dec 12, 2015 | 09:55 PM
Madpark72's Avatar
Madpark72
That's what I'm trying to accomplish is bleeding. The lines look to be in pretty good shape
Old Dec 12, 2015 | 09:59 PM
Madpark72's Avatar
Madpark72
I have replaced M/C, wheel seals, all new hardware, drums,shoes.
Old Dec 12, 2015 | 10:00 PM
Madpark72's Avatar
Madpark72
Manual brakes no booster
Old Dec 12, 2015 | 10:16 PM
72Truckin's Avatar
72Truckin
I have never replaced a M/C, however, everything I read about changing a m/c is that bench bleeding is the easiest way to get all the air out and prepped for installation.
The m/c can be bled while installed, but the vehicle will need to be level to bleed thoroughly.
Old Dec 12, 2015 | 11:35 PM
ultraranger
I have replaced ....wheel seals.....
Do you mean you rebuilt the wheel CYLINDERS or, you replaced the entire wheel cylinders at all four wheels?
Did you replace the left front, right front and the rear flexible brake hoses?
Old Dec 13, 2015 | 12:00 AM
Tedster9's Avatar
Tedster9
^^^ This. One thing about wheel cylinders, the new chinesium replacements don't always have the bleed port holes drilled in the right spot. Nice.
In any case prior to bleeding, wheel drums installed, turn the adjusters all the way out so the shoes are tight against the drum. The cylinder cups may cover up the bleed ports otherwise. Worth eliminating as the cause of trouble anyway.
Old Dec 13, 2015 | 05:54 AM
Madpark72's Avatar
Madpark72
I have replaced all wheel cylinders. I have a hand pump trying to bleed the brakes. It just seems odd that I can't get fluid to come threw the front or rear.
Old Dec 13, 2015 | 07:55 AM
Millam's Avatar
Millam
Not trying to be a jerk here but did you open the bleeders?
Old Dec 13, 2015 | 08:49 AM
Madpark72's Avatar
Madpark72
Not taken that way what so ever. But yes. I have even tried to push air threw the line with no success. I guess I'm just trying to avoid replacing the proportionate valves. That's the only thing left to replace.
Old Dec 13, 2015 | 08:55 AM
orich's Avatar
orich
Have you tried opening the front bleeders and blow air by mouth or compressor to make sure the theirs no blockage ? I'd open the tube nut at the M/C and see if any fluid is being pushed out when you pump a little on the pedal.
I believe you still have air in the M/Cyl. By slowing pumping the pedal a little at a time while watching for no more bubbles but a steady flow of fluid coming out every little push of the pedal. Then reconnect the nut tube line. And do you have the correct line hooked into the right M/C orifice as some M/C have the same size orifices on the M/C that come with a couple brass adapters. The M/C with the well closes to the firewall should go to the fronts if you were not sure.
Once, I get good fluid flow. I open the bleeder a number of turns and let it self bleed if no helpers around. Place a rag just under the bleeder to catch the dripping as not to make a mess. Always bleed the w/c farthest away first and open only one at a time.
Some people don't know much of this not saying you don't.
Orich
Old Dec 13, 2015 | 09:14 AM
ultraranger
All wheel drum brakes won't have a proportioning valve. Your factory valve should be a pressure differential valve like the one pictured below.
Diagram of the internal workings of the pressure differential valve. --The Metering Valve shown in the diagram only applies to '68-'72 F250/F350 trucks with optional factory front discs. '67-'72 F100s weren't available with factory front disc brakes. The metering valve would be omitted from the system with all-wheel drums.
Old Dec 13, 2015 | 09:29 AM
Millam's Avatar
Millam
Yeah. What Orich said...
Take note of the "Slowly pumping" bit. Pushing too quickly or letting off too quickly is going to splatter brake fluid around.
What I did years ago was to take a M/C cover and braze in two wheel air valves. One for each reservoir.
Use this on your M/C and pressurize the MC to 5-10 psi. Open the farthest S/C and wait a second for the fluid to flow. Close the valve and check the M/C fluid. Re-pressurize and go to the next farthest. So on and so forth.
As Orich says the system will self-bleed so you don't need to make the pressurizing cover.
But when the lines are all empty it takes more time, patience, and fluid to get the job done.
Orich
