Fuse panel location Ideas
Old Feb 9, 2016 | 04:56 PM
  #31
Jolly Roger Joe's Avatar
Jolly Roger Joe
Originally Posted by Tilleyman
What do they do? Are they necessary to have with the fuse panel?
Absolutely not.
My idea was to make it simple to disconnect everything when (if) I remove the cab someday. I was going to do it with 12-pin connectors, which I purchased, but I discovered the larger gauge wires for the 6 volt system didn't fit in the connectors I bought, so I regrouped and went with the barrier strips.
At any rate, they work fine. I haven't had any electrical problems with them.
Old Feb 9, 2016 | 05:00 PM
  #32
Tilleyman's Avatar
Tilleyman
Thanks so much. I was comfortable with doing the body and mechanical stuff, but for some reason electrical has me feeling shaky.
Old Feb 9, 2016 | 05:10 PM
  #33
eman92082's Avatar
eman92082
I call them "Terminal Blocks". I don't have any on my "Painless" Fuse Panel, but when wiring a vehicle, I can't live without them.
One example of several. I have 10 dash gauges. Gauge Pwr, Grounds, Bulb Pwr etc. Rather than tie everything together, I can remove a single gauge without tearing everything up.
If you need a lot of common connections for power or ground they make metal jumpers that can gang connect the terminals. My only caution is to keep an eye on current capacity if they are used in series with big draw items.
Old Feb 10, 2016 | 06:07 AM
  #34
Harrier's Avatar
Harrier
Ernie, That is extremely clean.
My wiring looks more like a rats nest at the moment. I'm not done yet though, so hopefully I will get it cleaned up a bit.
rbtom
Jan 2, 2015 05:50 PM
petes1818
2004 - 2008 F150
Oct 30, 2009 07:24 PM
rudy84
Feb 13, 2004 11:25 AM
champstang
Electrical Systems/Wiring
Dec 22, 2003 07:52 PM
thinesman
Sep 23, 2003 10:15 PM
