nv4500 for bumpside questions?
jasper offers 3 year warranty on rebuilt but wants a core and charges $3400 which seems too high.
i found another source online for about $1450. reasonable?
fordification thread says need a chevy clutch plate and don't go divorced:
NV4500 5 speed - The FORDification.com Forums
also it seems i should get one with a tail housing and a 5th gear modification for additional strength (details?)
tia
edit:
from the web, apparently the tailhousing for the "HD" version is different from the tailhousing for the "LD" version (beefier?), the "HD" is chrysler/dodge while the "LD" is chevy/gmc, and the "KA" version is for diesel and so will not work (right?). and if right, should i get the HD or the LD version? do i need a "spud shaft" on the rear end?
http://www.fordification.com/tech/transfercase.htm
at any rate it has a single **** and a high and low speed. [i have read that i should keep the dana 24 if i want to keep short term costs down, though a (somewhat stronger and slightly lower geared) np205 should in theory bolt in, so that is another option.] also i have a divorced setup, separated by a driveshaft that appears to be about 2 feet long (i think the truck was originally the longbed / long wheelbase version, although now a flatbed). i presume(?) this means, for simplicity' sake, that i should probably stick with keeping the divorced setup. what diameters and splines would i need on the front? what model # yoke would i need on the back? i may try to take a second look at the zf5 (but some quick links- to zf5-into-highboy would really help of anyone has some handy). oh and as far as hydraulic clutch, i thought that was only for the 385 series engines-- please help my confusion on that since i want to end up with something simple, and hydraulic does not sound simple to me (could of course always be missing something). My understanding is that the HD is used with the Dodge Ram gasoline variant, and for compatibility, the Dodge Ram gasoline variant is the way to go if at all possible.
The HD Dodge & Chevy diesels nv4500 internal gear sets are all basely the same, with that being said you can take the front input shaft from a small V8 gas eng. and swap it into a HD trans with it's bearing retainer. Early chevys up to 94 used a lower first gear ratio of 6.? that were good for rock crawlers Jeeps & Toyotas These lower geared tranny's can not be used in the ford trucks tho,as the input shaft were to short being 6.3/8"(or)5/8" can't remember now. But 1995 Chevy nv4500 was a new gear radio change to what the dodge was then using for it's diesels & gas V8's but the 1995 Chevy's were still using the earlier 92-94 bolt patterns with a small chevy short 6.3/8" input shaft.
The 1995 gas nv4500 was known as the B a s t a r d as it was a stand alone trans.
To make the 1995 chevy nv4500 trans usable the main case would have to be changed out to the 94 up to later dodge case up to yr. of 1996 along with a diesel "or" V8 gas input shaft that is now interchanged since the HD gears & V8 gas'ers have the same internal gears sets but different main out put shafts for the most part.
HD nv4500 diesels has a 1.1/4" input shafts, and the splines for the gas V8's has a 1.1/8" and both are 7.3/8" long both have 10 teeth on the gear. The input retainer is different size.
To get correct driveline angle and keeping it at 7* degree for installation into a f250 with remote having a TFC the 1995,96 Chevy rear tail shaft can be swapped out or changed out from the 94 up to 1996 light or HD Dodge nv4500 by using the Chevy short tail shaft and the use of the dodge GAS V8' a long with the bearing retainer.
The Ford 60/70's with having the remote TFC is the perfect candidate for this setup.
Ford's throw out bearing is the same size an fits the dodge gas V8 bearing retainer.
So no change with the clutch linkage, but a Chevy 11" clutch disc is used in stead of the fords 11" clutch.
The pilot bushing needs to be drilled out to match the dodge gas V8s size 3/4 or 7/8"
can't remember right now. A ez to do fix with a drill press an correct drill bit.
Center drive line has to be shortened 6"
The stock chevy tranny mount can be used or buy a stronger one of the poly mounts.
The stock cross member and the frame mounting brackets has to be moved back about 4.5" an drill new holes into frame and bolt it into it's new location plus drill for the new chevy mount all easy stuff.
Also about 1/2"-3/4" lip has to cut or trimmed off the cross member where it comes in contact with the rear of the tranny a little.
The 4wd shift lever mounting bracket will have to be addressed buy or make a new mounting bracket.
A new holes or replace tranny hump cover and make new holes for the nv4500 shift lever & 4wd lever.
I have a few picture in my garages/gallery.
Hope this helps clear your confusion some.''
I started out with a dodge HD Nv4500 an converted it into a dodge gas V8 input shaft with a Chevy V8 tail shaft pictured below.
The proof is when you pull one of these tranny's down. Also you can check ebay parts listing on NV4500 as it list chevy & dodge gears.
go look on ebay at nv4500 parts
This lower tranny pictured is the one I just built not long ago that up 4 sale
But not all of us can see the easy ways that just takes some a little thinking
Make a 4wd shift lever bracket not hard to do and use stock bracket mounted to it...
Transfer Case Basics - FORDification.com
Oh well just move cross member back 4.5" not hard to do.
Orich
Hey speak of the devil there's that shifter top tool. It's amazing how we were just talking about that. Then it shows up in the pic above in the background what a crazy quincidence.
what i have now
1968 ford f-250 4wd np-435 4wd transmission
main case length: 10.8"
front: 1 1/16" diameter, 10 spline, 6 1/2" stickout length input shaft
rear: 28 spline 1330 slip yoke (to internal driveshaft, to dana 24 divorced transfer case)
what i would need to install
1994-1996 (or 1992-1998? which? why?) dodge ram 4wd nv4500 sd (standard-duty)
(or equivalent with compliant components substituting non compliant components)
(note: non-compliant variations currently omitted for simplicity)
main case length 12.75"
front: 1.125" 10 spline 7.5" stickout length input shaft
rear: 4wd adapter housing length 6.25"
23 spline 1410(?) slip yoke
also required:
bell housing adapter plate(?)
chevy/gmc/dodge 11" clutch plate
longer bellhousing bolts?
custom shortened intermediate driveshaft
pilot hole needs to be drilled to larger diameter
miscellaneous:
nv4500 shaft needs to be ground down to 6.5"?
typical cutting and/or welding
caveats:
http://fordification.com/forum/viewtopic.php?t=47313
what i have now
also required:
miscellaneous:
caveats:
nv4500 5sp swap - The FORDification.com Forums
The married setup like for use in a f100's bolts up with the use of a inner coupler between them. Or for use in a bronco.
more to come later when I have more time got to go~~ foe now
