Camper-van Ideas
George
The sink basin is a steam table pan and a fitting would have to installed to connect to the drain hose.
The pan in the pic is $14 and measures 12"x10"x6".. You can get one 4" deep for $8. Cheaper if you have a used restaurant equipment dealer in your area you can also get smaller or larger ones.. what ever suits your needs.
Cut the hole in the counter, silicone, and set it in place..
The faucet is under $10 at ebay,, OR you can get a nice chrome 1/4 turn supply line shut off and a chrome supply line tube, bend it with a tubing bender and cut it to what ever length you desire.
A 12v water pump can be found for $10 to $15
The water jugs, price depends on what you want to use and what fits your cabinets..
I would recommend one color for fresh water and the other for grey water..
Counting up all parts, for complete sink with running water, around $60
You might be able to find a small used sink with faucet a little cheaper at the used restaurant supply dealer..
It's tough going back. I just graduated after going back at 36yrs old. My brain just didn't seem to absorb the info like it used to. Made it through though....Accosiates in Network Admin and BS in Info Security.
Here are some pics that I downloaded from a website a couple weeks ago that have floor plans. I was planning on printing them out and cutting them up and laying my own out with a better reference for sizes needed and such, but I still haven't gotten around to it just yet. I figured that some of you guys might actually like to use them for the same reason.
R-Values in the Real World SIPs | SIPA - Structural Insulated Panel Association
I don't need an actual sink and running water...for me thats something needed (and of course expected) at home, but rarely if ever when camping.
In a camper, where water can be a precious resource, sinks can be quite wasteful when it comes to water use and limited camper space. Large water storage tanks can be heavy, bulky, and the plumbing required adds mechanical complexity and has the potential of freezing and/or leaking.
You can make do quite easily with a couple of spray bottles and some other supplies, (scouring pads, soap, washcloths, towels) depending on what you need.
I keep a trigger sprayer, a very small pump sprayer, and a small squeeze bottle, all filled with clean water. I do keep a few gallons of fresh clean water in small one gallon bottles. I also have a couple of small squeeze bottles (one with shampoo and one with dish soap)
diluted about 10:1 (water to soap ratio).
I can rinse and clean dishes, bowls, and cups, do some light cleanup, take a spit bath, wash my hair, keep up with personal hygiene, and clean up after light cooking and mealtimes. Of course I'm using plastic disposable utensils and paper plates a lot.
No installation or cabinet work needed, takes up very little space, no large tanks of grey water, and its all very portable and cheap.
Might not work for everyone, but us bachelors can live pretty simple when camping.
These are 5 gallon heavy duty rubber water containers, surplus from the Swiss army.
If you hang them out in the sun during the day you have nearly hot water for the dinner dishes or a warm shower. They are extremely heavy duty, to that point that you run them over with your van with no leakage at all.
When they're empty you just roll them up and tuck them away.
I tried the black solar shower bags and found they didnt work that well for me. They might work well for summer use out in the boonies, and for the females (or dudes) with long hair, they would probably work well.
But they are heavy when filled and need to be hung pretty high above the user, and thats not always practical in my situation.
I found that a clean, new, black, HDPE plastic, oil recovery bottle works well for warming water in the sunshine, and then you can pour a quart or so into a spray bottle and have a nice little mini-shower available either inside the van or outside the van in an enclosed area such as a stand-up tent or shower tent or between a few trees, or anywhere you can find that provides whatever privacy you need.
I have seen the black solar shower tubes that are mounted on the top of the van, but the cost seems a bit high for the little use I would get from one.
Anyway, I think that all of these options can help anyone thats trying 'van-camping' for the first time.
Here are a couple of interesting space saving ideas I came across for a camper van.
This looks to be a full length bed where the foot section can fold down so it doesn't block the side door. If you notice it also includes storage for a porta potty under the foot of the bed..
The sink idea is quite simple eliminating the need for a pump. It looks like you just lift the sink/pan to dump it and push it back in the cabinet when not needed. One could always add a grey water tank at the bottom.
other pics here
https://get.google.com/albumarchive/...to_?source=pwa
We can sleep anywhere for free. My biggest challenge is my wife does not like to use a porta potty. We have to leave early in the morning for real toilets.
