'54 Wiper Arm Post
Old Dec 8, 2015 | 07:16 AM
544tess's Avatar
544tess
'54 Wiper Arm Post
How do the knurled/splined caps stay on the wiper pivots?
Ours were stuck in the wiper arms which were not on the truck when we bought it.
In the pic below it looks like the knurled cap is staked on.
Old Dec 15, 2015 | 11:35 AM
petemcl's Avatar
petemcl
Everyone that I have seen has been staked. I suppose that there would be no reason why you couldn't drill and tap it if there wasn't enough material left to hold when re-staked. Else buy a new one or I might try a quick, mig spot weld just enough to hold it. Just make sure that you ground to the shaft and not the pivot body else you may damage the shaft-to-body bearing surface. AX may have some advice on that.
Old Dec 15, 2015 | 06:42 PM
56panelford's Avatar
56panelford
1953-55 Ford F-100 Wiper Cowl Pivot Assem 5355 - BAAA-17566
Cheap fix would be buy a new one and be done with it I think.
Old Dec 16, 2015 | 02:47 AM
big job's Avatar
big job
Very common back in the day these were "pinned" exactly like inside door and
window handles.... I remember early 1950's my father had a Anco tin box full
of those all sizes knurled & pins. I do remember Chrysler products 1930's-40's
were pinned. My fix is drill it with 1/8 drill and with a cut off 'whizzer' a piece of
the drill. So don't through busted drills away. ......
Old Dec 17, 2015 | 07:03 AM
544tess's Avatar
544tess
I just pressed the arms back onto the posts.
I had to go under the dash and apply pressure on the pivots while my wife pushed the arms on.
If they start causing problems,I will buy new pivots.
Thanks.
aj88V
28
Feb 15, 2016 02:37 PM
Bluey Zedoff
Dec 15, 2014 12:59 AM
bigshotsho93
Aug 21, 2009 01:37 PM
rsylvstr
1997 - 2003 F150
Jan 19, 2007 06:45 PM
Delaware04F-150
2004 - 2008 F150
Oct 31, 2004 02:30 PM
