The indicators were working fine.
Then when I went to go out again the indicators no longer worked?
However the four way / hazards, lights and brake lights work fine.
I also noticed the fuel and temp gauge were not working as they were either.
I have not had chance to look at it yet.
But thought may be some one else has had this problem?
I am hoping some will tell me its the fuse?
Hope its not something that turns out to be impossible to find.
I need the truck at the week end.
Check the flasher too. There is a separate one for the turn signals and hazards. I have the same issue and have it pretty much narrowed down to a ground issue, so +1 for that idea.
I believe the OP is referring to the dash cluster.
HIO - Thanks for the clarification.
Yes, the temp and fuel voltage as well as the gauge cluster are controlled by the ICVR. It sends out a square wave pulse of ~ 5.0 volts so it's difficult tp check with a meter. It will fluctuate at times, too - from nothing to full up readings. It's also adjustable - HIO's picture (#6).
I suspect while fiddlin' and diddlin' behind the cluster face you disturbed a ground or the ICVR - made a better connection - or played with some bulbs by accident that made a better connection. Recheck your grounds again- engine to frame, frame to battery, cluster to dash, cluster connections (that 18(?) point pin that goes into the plastic circuit board), the plastic circuit board itself, etc.
Roger: Thanks....I knew that but fergot something along the way...didn't read it all, I suspect.....too many moving parts with only two fingers to type...................
Two fingers?? You must have taken the advanced typing class.
