stereo installition
Old Aug 6, 2003 | 10:33 PM
hermangarza's Avatar
hermangarza
stereo installition
what kind of dash adapter do u guys have on you 80-84 truck? im really looking into one but i was wondering if there was one with room for an equalizer?
thanks
Old Aug 7, 2003 | 12:27 AM
Txquadhunter24's Avatar
Txquadhunter24
stereo installition
The EQ can be Easily Molunted Where the Factory Clocks are/suppost to be in the 80-86 trucks if the EQ isn't that large. If your truck doesn't have a Factory Clock Look right above Where the Stereo Mounts and You'll see a Place to cut out for it.
Old Aug 7, 2003 | 06:56 AM
bremen242's Avatar
bremen242
stereo installition
I just took the old one out, used the metal bracket, and cut it open wide enough to fit my cdplayer, and bent the tabs that have the holes for the shaft mount, and used those holes to mount my radio. not perfect, but the radio is mounted very solid
Old Aug 7, 2003 | 11:21 AM
hermangarza
stereo installition
u know how on some trucks where it says custom or xlt on the top of radio would an equalizer work there?
Old Aug 7, 2003 | 04:59 PM
bremen242's Avatar
bremen242
stereo installition
probably not without a lot of work. My radio has an EQ built in
Old Aug 7, 2003 | 10:00 PM
Txquadhunter24
stereo installition
Herm. Thats the Place where the factory clocks are in those year trucks. If you've got a stand alone EQ measure and see. Because that hole can be Cut larger then the Cut out pantel there. Most EQ's out now are small enough to fit in it's place. My Kenwood KDC Cdplayer on my 86 I just had to shave a little off the Factory Plastic Radio pantel to install It. It holds well enough it don't Skip even when out playing offroad in a 2wd truck.
Old Aug 7, 2003 | 10:02 PM
brown 4x4's Avatar
brown 4x4
stereo installition
I've seen an equalizer in the glovebox on an '80. That would work if you weren't going to be messing with it a lot.
Old Aug 7, 2003 | 10:09 PM
hermangarza
stereo installition
i need to meassure first but i saw some where a dash kit with a pocket but i cant remember where
