Was it new when purchased? If so you can look at the window sticker that was on it when purchased. It may be a standard option in the EB package. Also you can look for a double row radiator and a transmission oil cooler. I would imagine it has the full package unless the dealer installed the hitch.
Originally posted by ok-expy I recently purchased a 2003 Expy EB. I have the 5.4 engine and most of the goodies. My question is whether I have the tow package?
Checked the door sticker and I have the 3.73 LS rear end. Also have the hitch in back with both wiring plugs.
Anyway to tell for sure if I have the full package for towing?? Thanks in advance!
Do you have a tow bar/hitch?
That 3.73 sounds like you have the tow option if you have a towbar/hitch.
It does have a receiver hitch in the back - is there anything else I should look for or am I good to go? Any other sources I could check (VIN, stickers, etc?) Thanks!
