RADS
Old Dec 5, 2015 | 10:58 PM
barkfarm's Avatar
barkfarm
RADS
the RABS on my 1992 f350 will not let the rear brakes work at all. So the brakes work very poorly, Was working find and just stopped working. How do I test to find out if the RABS module is bad.
Old Dec 6, 2015 | 10:18 AM
barkfarm's Avatar
barkfarm
RABS
RABS Is the right term that I was asking about.
Old Dec 6, 2015 | 01:14 PM
bashby's Avatar
bashby
Have someone hold the pedal down while you loosen the line going into the RABS valve. It should leak fluid out and the pedal should drop. Tighten it back up then do the same with the line coming out. It should do the same thing. If not the RABS is in fact causing your rear brakes to not work. You can bypass the RABS valve if it is bad. The system never was all that good.
Xwarrior86
Jun 1, 2015 08:02 PM
michaelbrainardatwor
Nov 3, 2009 07:10 PM
sumdumgai
Jun 13, 2009 04:02 PM
Ron McCafferty
May 18, 2006 11:11 AM
velcro7279
Dec 19, 2005 07:38 PM
