I have a ford f250 super duty and it wont start I have checked obvious reasons and I think it might be a crank shaft sensor. Just curious, is there two of them one for right bank and left bank or just one on drivers side?
You didn't identify the year (always necessary) of your truck, but on the ones of the vintage of mine, the CKP sensor is buried behind the compressor and the connector plugs are often confused between the sensor and the clutch coil.
I'm changing the title of your thread to make it a little more specific. What makes you think it's the crankshaft sensor? I'm assuming there are trouble codes present, which ones are they? Knowing which year your truck is would also help.
