I NEED HELP WITH THE GAUGES
thanks mike i ordered the ones right below your picture,they came in just 3 days ago i had them installed boy they sure are nice when i drove the truck for the first time today with the new gauges it was nice but the i only went about a 1/2 mile and the temp gauge showed 250,i know that everything was new and that could not be right i took it back to the installer and he did some reading and the top hose was only 160-the bottom was 145 so i called early ford and asked what was wrong and he said that if he put teflon tape on the threads that would give you a false reading so now i have to take it back to the installer-if that does not fix the problem then i have to call EARLY FORD again
mustangmike, you are right i took my truck back to the shop and they removed the tape (i was not going to do it that is what i paid them for to install and make sure everything was working like it should) that was the problem now it is ok--boy am i glad that i had them put and calibrate the gauges and speedometer in my truck i know that i never could have done it-now everything is all done and i am happy
54ford100
03-03-2010 06:23 AM
