93 7.3 IDI build
#77
#78
#80
How far back does the frame extend from the rear of the cab? Seems quite, quite short. But maybe it's just the angle on the last few weeks of pictures... Anyway nice work!
#82
#86
this is a EZwiring harness.
super sinple to install.
the hardest part was getting the fuse block in the stock location
i had to gut some of the dash plastic to do it, but i wanted it in the stock location
here is a link to the harness.
EZ Wiring E-Store - EZ Wiring Harness Kits
#87
#88
#89
Ah ok. Did you update the connectors on the engine sensors and lights? If so, where did you get those? Ford? Sorry about all the questions. I just have to do something similar to this.
#90
the stock connectors and sockets will be used. i have a few harnesses from previous trucks.
ill be using most of the stock connectors, soldered and shrink wrapped.
tach sensor has the stock harness also.
i ordered a new glow plug harness so the
GP's & IP all have new clips and plugs.
the wiring from the fuse block only goes to the starter, glow plug relay, temp switch, FSS,
i also have updated gauges, so the oil and engine temp are ran independently.
i know im missing something, but im not at that stage yet.
getting ready for this weekends festivities so work on the truck is on hold till monday
