manual steering
Old Dec 1, 2015 | 10:21 PM
NS70250's Avatar
NS70250
manual steering
My '70 F250 is a 4x4 and has power-nothing except the engine. The steering box (not sure I'm using this name correctly) has a rubber seal of some type that is falling apart. It has a giant hole in it. Is this something I can/should replace? -thanks everyone
Old Dec 1, 2015 | 10:27 PM
mountain dewd's Avatar
mountain dewd
If there is a possibility of foreign matter intrusion where there shouldn't be, it would be a good idea to fix the seal.
Check out stangerssite.com for steering rebuild info.
Old Dec 2, 2015 | 12:19 AM
351Cleveland C4's Avatar
351Cleveland C4
Get a redhead steering box if you need it and can swing it.
Old Dec 2, 2015 | 06:03 AM
willowbilly3's Avatar
willowbilly3
I'm having a little trouble visualizing what you are talking about. Could it be you are looking at the boot on the drag link where it goes into the steering arm.
Old Dec 2, 2015 | 08:10 AM
crazed87bronco's Avatar
crazed87bronco
If it's any type of seal that's falling apart I'd imagine it's time to replace it before any damage occurs. Can you take a picture of it? Not sure exactly which seal your referring to so a pic could help us help you.
Old Dec 2, 2015 | 10:12 AM
Gembone's Avatar
Gembone
EDIT: removed to keep the confusion out.
Old Dec 2, 2015 | 10:53 AM
orich's Avatar
orich
That rubber seal on the bell lower end of the slip coupler on the mid shaft can be had and replace by using the early jeeps Boot. Jeffs bronco's grave yard has them. But the small end needs to be re-shaped to fit the round ford shaft.
Get the rebuild kit help reduce steering play.
Also the side box adjustment screw with the luck nut can be adjusted but don't over tighten that.
Adjust while tires our straight and test drive after each time you make any adjustments to the box.
I use a small 1/2" sanding drum with my Dremel hand tool to grind out the rubber.
If you don't do this , It's a real B-ch to get it on to the shaft with the end Tee cross bar shaft
I'm sure you can get it at any jeep dealer this fits like the 80's cj5 or cj7
Orich.
Old Dec 2, 2015 | 10:59 AM
orich's Avatar
orich
ahhh double post deleted Dang slow wireless laptop
Old Dec 6, 2015 | 10:28 PM
NS70250's Avatar
NS70250
i think i may be asking about a boot on the rag joint? ... working on a picture
Old Dec 6, 2015 | 10:30 PM
crazed87bronco
A 4x4 box does not use a rag joint. Only 2wd's use a rag joint in there steering systems.is it a slip joint your meaning on the steering shaft between the box and column?
Old Dec 6, 2015 | 11:38 PM
orich's Avatar
orich
Here's what the replace kit looks like.
The bell & a new boot with inner blocks with alignment clips.
This mounts onto the box.
Now on ebay
Orich
pezsox
Dec 25, 2019 12:11 PM
CooGAR
Oct 14, 2010 10:42 AM
