Sponsored by: Auxito
Whinning noise while in reverse
Old Nov 29, 2015 | 11:08 PM
bronco6767's Avatar
bronco6767
I have a 202 f150 with the 5.4 motor and a auto transmission and when I go in reverse the rear end makes a loud whinning noise? The fluid level is fine. Should I add the gear oil additive to the rear end or change the rear end oil and add that? I am looking to sell the truck so if anybody has any ideas as to what could cause this noise it would be great.
Old Nov 30, 2015 | 01:26 AM
thzpcs's Avatar
thzpcs
Unless it's very loud, this is most likely normal. Typically in a transmission, all of the gears are helical. They mesh a lot better than straight cut gears, but are more expensive. Most reverse gears are straight cut, which tend to whine when they get up to speed. Could you take a video of the noise? It would help determine if it's a normal whine or not.
Blueeyeseskimo
1983 - 2012 Ranger & B-Series
Jul 31, 2019 04:52 PM
Crazyokie11
1997 - 2003 F150
Sep 28, 2009 10:40 PM
BIG-DOG-DADDY
Oct 16, 2008 12:42 PM
MILariat
2004 - 2008 F150
13
Jun 17, 2008 08:22 PM
