1973-1979 Interior
1973-1979 Interior
Category: Interior
Price: $65
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude
Item Condition: KS
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck, Part suitable for diesel truck
Automatic 4X4 transmission floor pan pulled from 78 F250
$35
Black ashtray $10
Black and Chrome Dash Bezel Doesn't have Air Conditioning vent $60
I also have these which aren't all interior parts:
Borg Warner 1345 Transfer Case
2-Syracuse Transfer Cases
regular cab white headliner trim (I also have a chrome set)
73-78 Custom headlight buckets (round with aluminum holders)
Front 4x4 drive shaft
Dome light
Transfer case Shifter (2H 4H N 4L)
Fan without fan clutch
Clutch & Brake Pedal Set (includes mounts and pedals)
Rear fuel tank bottom straps
Big & small block fan shroud
460 Auto block plate
Hood latch
Engine frame mounts (from 78 F250 with 400)
Brake pedal
Ford jack clamp
4-Factory air breathers
Rear drive shaft
2-Accelerator pedals
400 Manual transmission 180 tooth flywheel
Windshield Washer reservoir
Clutch shift linkage
Manual Transmission mount
3-Vent Windows
Front coil springs 4X4
New F250 rear leaf springs
Power brake booster & Master cylinder
Rear fuel tank
3 Moog 434 U joints
Heat-A/C dash vents
3-80's style steering wheels
2-chrome antennas
Outside mirrors
4X4 and MT shifter floor chrome trim
4X4 MT floor Pan-SOLD
Window guides
Ranger glove box trim
2-black glove box doors
Manual transmission steering column
3-Gauge clusters
2-Steering wheel collars
Red upper seat belt cover set
F250 Custom hood cowl emblems
window regulators
black seat belts
Custom glove box trim
Cargo light
Cargo light Switch
73-77 ignition switch
Washer nozzle set
Outside door handles
6-Turn signal arms (chrome & Black)
6-Manual window handles (Saddle & Black)
Rear Axle bearing
Tie rod end
Fuel Tank Selector Valve
3-Ignition Control Modules
NP435 4X4 4 Speed transmission
Jeg's 460-180 tooth MT flywheel 12" Clutch Brand New
Steering gears for 78 F150 4X4
4-Rectangle Headlights
3-Round Headlights
Dana 44 Front axle 3.50 Gears
460 MT flywheel 5 speed transmission Brand New
I bought a couple more pickups and have quite a few more mechanical parts to add to the list
FE Series Bell housing
Big block clutch fork
360 MT flywheel
360 AT flywheel
FE series MT block plate
FE series AT block plate
Windshield washer reservoir
360/390 roller rocker arm set
360/390 valve covers
360/390 fan
360/390 pulleys/balancer
360/390 timing cover
oil filter mount
5 side windows
2 rear windows-non-sliding
I haven't gotten one of the pickups fully taken apart yet but I will post more parts from it as I get them taken off.
So I don't get out of hand with all these items pictures that's all I'll list in this post if you have questions, want pictures or information, about a certain item or want to purchase items please private message me.
George Fletcher
Ford Truck Parts for Sale
02-28-2016 07:22 PM
EndorphinJunky
424
03-23-2015 05:15 PM
