Bullnose Parts Parted Out 3 1980 F250's Probably Have What You Need!
Category: Drivetrain
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Fit, S2000
Item Condition: KS
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck, Part suitable for diesel truck
Interior Parts
2-Rosewood dash bezels-includes AC/Heat Vents
1-Ranger XLT center dash bezel-radio, heat A/C controls, no clock
2-Metal Dome lights
2-chrome door trim sets
speedometer With trip meter
4x4 Chrome shifter trim
Saddle dash
Blue Dash
Gauge cluster lens
Fuel gauge
oil pressure gauge
heat gauge
charge gauge
2-1980 circuit boards
3-steering wheel collars
9-Chrome Inside Door handles
3-steering wheels
blue glove box door
saddle glove box door
Saddle upper trim reg. cab
2-Automatic steering column
4-window regulators
1-gauge cluster-Gasoline,no odometer, no tach
2-blue visors
3-Brake pedals
3-gas pedals
2-blue kicker panels
blue upper trim set reg cab
2-blue rear corner trim
rosewood steering wheel center-no cruise control
blue steering wheel collar cover
saddle steering wheel collar cover
6-turn signal arms
4- striker set
2-blue slide lock set
10-window crank handles, clear, saddle, black,
7-Vent windows
3-rear windows non sliding
4 side windows
Mechanical Parts
Small block radiator
2-fuel filler plastics-duel tanks
rear fuel tank
5-Fans-I have both with clutch and some without
3-Driver side passenger side window guide sets
3-Driver side passenger side latch & rod sets, non slide types
Small block fan shroud
2-big block fan shrouds
2 Borg-Warner 1345 transfer cases
351W MT block plate
351W MT flyweel
3-4X4 shifter levers and *****
3-Air cleaners
2-Motorcraft 2BBL carbs- one needs new gaskets
351W MT aluminum bellhousing- Non hydraulic clutch
3-Power steering pumps
5-power brake boosters With master cylinders
203 Syracruse transfer case
2-205 transfer case
3- Automatic 4X4 floor pans
3-MOOG 434 U-Joints Brand New
2-Blower motors
2-Hood latches
2 front fuel tank straps
2-washer reservoirs
fuel tank switcher
3-ICM
2 NP435 4 speed transmissions
Jegs 180 Tooth MT 460 flywheel Brand New
ATP 176 Tooth MT 460 5 Speed flywheel Brand New
2 Dana 44 Twin I beam front axles with leaf springs 3.54 ratios locking hubs
1980 F250 Reg cab long box frame with front leaf springs
1 Dana 44 solid axle 3.50 Ratio
Cosmetic
8-Outside Chrome door handles
2- Windshield chrome trim sets
2-Ranger F250 emblem sets
Bottom grill chrome
2 Tow mirrors
3 chrome antennas
XLT tailgate emblem
black bug shield
6-mirrors
1980-1986 Brown long box
I have more parts as well, that aren't listed if you have one in mind feel free to ask and I might be able to find it. Feel free to private message me about and of these parts. I also have 1973-1979 pickups that I've parted out https://www.ford-trucks.com/forums/1...-interior.html
I tried to send a pm, but I really don't know if I did it correctly so I thought I would just reply. I wanted to know if the saddle upper trim are the plastic pieces on each side of the window in the cab. If so, what shape are they in and what do you want for them?
Also interested in the washer reservoir.
Zip is 25526.
Thanks,
Tim
Zip is 25526.
Thanks,
Tim
Yes, all these parts are still available
Jmerchant6_9
07-05-2018 07:34 PM
EndorphinJunky
Ford Truck Parts for Sale
26
01-12-2017 01:58 PM
toddspeed
70
01-20-2014 12:44 PM
cbfomoco
03-09-2006 04:59 AM
