Busted rear hatch window!
Old Nov 29, 2015 | 12:22 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Okay luckily not mine! My friend who has two of my old Ex's and her silver '04 shut her hatch window first and then went to close the barn door and, well you know how that goes.
My question is, she has my old 2000 Ex for parts. Can the window be removed from the hatch itself or do we have to swap the whole hatch between trucks?
I've searched for a parts blowup but can't seem to find one, any insight?
Old Nov 29, 2015 | 10:23 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Yes, you can remove the glass from the hatch. It is held in there by 16 nuts and some butyl rubber sealant.
https://www.ford-trucks.com/forums/1...-and-info.html
Old Nov 29, 2015 | 10:57 AM
1 Excursion camper's Avatar
1 Excursion camper
Ouch! I've come close to that myself. If she don't mind the color difference of the top of the hatch (or the inside of the hatch) you could swap the entire thing over.
Old Nov 29, 2015 | 11:20 AM
HiZ's Avatar
HiZ
Trim comes off from top down. Sides have some hidden fastners.
The GLASS is held on with Nuts'
Studs are fastened onto the glass, when I tried to remove to reseal the upper section of mine there are 5 studs that would Spin, So i moved to other ways and didn't remove.
Once all the gunk and plastic and crap is removed you will see the nuts
I vote to swap the entire rear hatch with 4 studs!
On a side note, Anyone have much luck fastening the defrost tab back on the glass?
Old Nov 29, 2015 | 02:37 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Luckily the other truck is black, so the color difference would not be that noticeable.
Thanks guys!
Old Nov 30, 2015 | 06:44 AM
1 Excursion camper
If you haven't tried gluing it on (don't)! you can resolder it. I do it all the time. the localized heat will not shatter the glass.
Good luck!
Old Dec 8, 2015 | 11:49 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I should finish this story off, eh?
So her Husband is up north working for 3 weeks and her Father is out of state at the moment, so she had nobody other then me to do the work. She lives 55 miles one way from me and it's been chilly so she told me not to worry about it. Ended up buying new glass and having it installed at a shop, along with a new windshield.
She said she saved the parts Excursion glass for when she really needs it, seeing as how she has two daily driven Ex's.
78ford351m
Apr 9, 2011 06:27 PM
Thunderduckie
Nov 6, 2009 12:52 AM
aerocolorado
Aerostar
16
Jun 2, 2008 11:56 PM
68step
May 10, 2004 07:03 PM
arostar
Aerostar
Apr 27, 2003 07:54 PM
