E40D tranny going into "neutral" while driving
Old Dec 1, 2015 | 06:27 AM
Az_Green_Machine's Avatar
Az_Green_Machine
Originally Posted by Robbieyarks
I have a trans temp gauge doesn't get hot fluid is still perfect. It's not a slipping feeling it's literally in neutral won't go no where if you floor high rpm the truck will force it self to shift very hard and o/d light flashing. I guess I just need to bring it to an automotive electrically specialist
O/D light flashing means the trans is detecting slipping and then over pressurizes to stop it, that's why it shifts hard. If the trans was rebuilt 4-10k miles ago I'd take it back to who ever built it and have them look at it. Any reputable shop will stand behind their work. Just an FYI my trans did the same thing, there's a big chance you'll be having it rebuilt again because these trannys don't like that stuff. Oh and BTW just because your temp gauge doesn't show it being hot doesn't mean it isn't, depending where your gauge is it may be clogged with debris and not receiving flow and giving a bad reading.
Old Dec 1, 2015 | 07:06 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The flashing OD light means the computer has detected something is wrong with the transmission system. Slipping is only one of about 50 different things that could make the OD light flash. The only way to know why the light is flashing is to get the codes read.
Old Dec 1, 2015 | 07:14 AM
fordman67's Avatar
fordman67
In the late 90s and 2000s we replaced a LOT of MLp at the dealership. There massive water intrusion issues dating to the beginning of e4od use. Most people don't understand how crucial it is. Listen when you go from park to rev and to n again . The engine should change rpm slightly due to the load anticipated. Most I see don't change. The truck may work ok as mine did but not 100% correctly. Replaced mine with no codes or symptoms other than I knew it was not right.
Listen to mark on this. Lots of these would fall out of gear and MLp fixed it.
Old Feb 14, 2022 | 05:44 PM
OldFordKen's Avatar
OldFordKen
Did you ever get this resolved? I have the same issue.
Old Jul 19, 2022 | 07:06 AM
Canes_Fan_Ken's Avatar
Canes_Fan_Ken
2nd Gear
Did anyone come up with a solution for this? I started having the same issues. Replaced vss with a factory one, mlps along with multi use switch on column.
next step I guess is to trace wires.
Old Oct 30, 2022 | 03:28 PM
Logan1234!'s Avatar
Logan1234!
2nd Gear
i just replaced my mlps\nss\trs and the tps and still having this problem. Did you get yours figured out?
Old Oct 30, 2022 | 03:56 PM
Canes_Fan_Ken
2nd Gear
I took the cluster out and sent it off to be checked. The speedometer repair shop said the psom had a capacitor that was going bad and causing an intermittent signal which was causing it to drop into nuetral. After having it repaired for about a hundred bucks, it's been a month now and has not dropped since and the CEL light went off on its own.
Old Nov 5, 2022 | 02:04 AM
Logan1234!'s Avatar
Logan1234!
2nd Gear
Proble
Problem fixed. Replaced the vss on the tail shaft of transmission and the problem with jumping into neutral is fixed..
Old Aug 25, 2024 | 05:51 PM
TT_Vert's Avatar
TT_Vert
4wd Low
I know this is an old thread but what exact symptons did you have and what led you to the speed sensor? Was your speedo ever erratic/jumping??
Thanks
Dave
Old Aug 26, 2024 | 02:40 PM
tjc transport's Avatar
tjc transport
i ain't rite
he has not logged on since making that post close to 2 years ago.
Old Aug 26, 2024 | 02:43 PM
TT_Vert's Avatar
TT_Vert
4wd Low
Ahh, thanks. I hate bringing up old threads, but I didn't want to start a new one if he had some pearl of wisdom that would help me.
Dave
E55 Bulldog
Mar 22, 2016 10:03 AM
countrysF250
Apr 26, 2008 07:28 PM
karkraft55
1983 - 2012 Ranger & B-Series
Dec 22, 2005 06:54 AM
SDW
1997 - 2003 F150
Jan 31, 2004 08:18 AM
qhfan2
Sep 11, 2003 12:18 PM
