rebuild or replace?
Old Nov 28, 2015 | 04:15 AM
jerryparks's Avatar
jerryparks
rebuild or replace?
As said in the title, I'm looking for some opinions on whether I should rebuild or replace my motor. It's a 300ci with 190k on it. It's been over heated several times since I bought it in April with 179k on it. By several, I mean at least 10 - 15 times sitting on the H. Recently I noticed that my coolant was black/brown and my oil looks suspiciously like coffee, which shouldn't be the case ssing as the entire cooling system was replaced at 185k and I just replaced the oil at 189k.
My conclusion is probably a blown head gasket or a cracked head. I have minimal white smoke during start up and acceleration, and some power loss. The motor has a very heavy tick.
Thoughts? Ideas? Solutions?
Old Nov 29, 2015 | 08:40 AM
whiskey runner's Avatar
whiskey runner
changing the oil and replacing the coolant will not completely clean the engine oil or cooling systems.. new oil and antifreeze will normally discolor in a older engine fairly fast.. not sure what you mean by "coffee'... a chocolate milk shake look to the oil or coolant would worry me about a head problem a lot more.. id run a compression and leak down test on the engine before rebuilding just to get a idea on what i am dealing with
Old Nov 29, 2015 | 11:12 AM
The Frenchtown Flyer's Avatar
I'd bet the head is cracked. I would look for another head, rebuild it, and swap it out. If your old head is in fact still good find a new owner for it.
Old Dec 1, 2015 | 10:28 PM
jerryparks's Avatar
jerryparks
The oil is foamy and light brown. The coolant was flushed then filled when it was replaced.
Can someone recommend a Thread with a head rebuild?
twg1966
Jun 16, 2017 10:07 AM
JayFinAZ
54
Jan 28, 2017 08:00 AM
marks500
16
Oct 7, 2010 11:20 PM
YamakidCR500
General Automotive Discussion
Jun 6, 2009 09:20 AM
Dlobacz
Feb 16, 2008 08:15 PM
