1978 - 1996 Big Bronco
What is this,,, do i need it?!! Help
Old Nov 26, 2015 | 02:46 PM
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
Ok,,, going to put fuel tank in my 78 Bronco,,, this is on frame right in front of fuel tank,,, what is it,,,
Old Nov 26, 2015 | 04:45 PM
85e150's Avatar
85e150
Where do the lines go? If it is part of evap, you will need it to pass smog.
Old Nov 26, 2015 | 08:28 PM
Pickupmanx2
Do not know where lines go,,, had a loopback on it,,, nothing can go to it,,, other than fuel line in and out?
Old Nov 27, 2015 | 06:11 PM
85e150's Avatar
85e150
I see a small line, a rubber hose making a u-turn and a larger line with a flare of the type I associate with connecting a rubber line to a hard line....
The small line goes nowhere?
Old Nov 27, 2015 | 07:17 PM
Pickupmanx2
small line is electric, is it a pump of some sort?
Old Nov 27, 2015 | 07:19 PM
Pickupmanx2
Never seen one before,,, appears line would come from tank into it, out of it to fuel pump/carb
Old Nov 27, 2015 | 08:23 PM
moose4x4's Avatar
moose4x4
FTE Remembers
Electric fuel pump someone installed. Not hooked up now. Not factory. No you do not need it. have a good day. Bruce
Old Nov 27, 2015 | 10:01 PM
Pickupmanx2
Thank you sir,,, was trying to find any numbers or anything,,, that is kinda what i was thinking, just by looking at it, but had not seen one like that before. Made the maiden voyage around the neighborhood,,, 4 miles just to see! All is well!!
sctrt
Feb 3, 2012 12:07 AM
van_350sd
Jul 21, 2010 03:48 PM
Midwest Dually
May 27, 2010 08:01 PM
85-4X4-6.9F250
Feb 7, 2010 12:08 AM
Randy777
Oct 7, 2007 01:37 AM
