Modular V10 (6.8l)
Correct Oil for V10
Old Aug 6, 2003 | 02:36 PM
kirkjrk's Avatar
kirkjrk
Correct Oil for V10
Recently purchased a Motorhome with a 2002 V10 engine. I had the oil changed at Camping World and asked beforehand if they knew the correct oil to use,not to insult, and the answer "we certainly do". When I picked up the MH the service order read 10-30 oil was used. I spoke with the Service Mgr and told him they used the wrong oil---that Ford manuals call for 5-20 and even the oil filler cap has 5-20 on it. He said 10-30 is the correct oil for this engine definitely. I asked him to show me proof and he was unable to produce that info.
I guess I should call Ford and ask but I thought the forum might have something to add. Is it possible for the 10-30 to hurt the V10 for 3000 miles? Does anyone now use 10-30 in one of the newer V10s.
Old Aug 6, 2003 | 03:08 PM
ktm520mxc's Avatar
ktm520mxc
Correct Oil for V10
I think Ford came up with 5-20 for environmental reasons. I don't think the 10-30 will hurt but that is just my opinion.
Old Aug 6, 2003 | 04:15 PM
Baja Daze's Avatar
Baja Daze
Correct Oil for V10
It won't hurt a thing. You're fine.
This lightweight 5W20 stuff is only to increase their fuel milage numbers.
Old Aug 8, 2003 | 04:05 AM
FordF150_1996's Avatar
FordF150_1996
Correct Oil for V10
5w20 oil sucks. Its too thin. I'd use 15w40.
Old Aug 8, 2003 | 07:01 AM
HD Power's Avatar
HD Power
Correct Oil for V10
I dissagree, 15w40 is too heavy of an oil for this engine , I would NEVER put that weight in my truck. Go with the the 10w30 if you don't want 5W20.
Old Aug 8, 2003 | 07:29 AM
V10KLZZ71S's Avatar
V10KLZZ71S
Correct Oil for V10
10w-40 havoline for about 2 yrs, no problems.
Old Aug 8, 2003 | 10:56 AM
daimon1054's Avatar
daimon1054
Correct Oil for V10
You will get a bunch of answers on this, you shoud see the same question asked on a motorcycle site.
In the end you will hear
Synthecis suck they runed my motor
Svnc's are great I go 500,000,000 miles and never touched a prat
Hevy weight sucks it will burn your motor
light oil sucks it will burn your motor
And on and on and to a man my self included don't know squat!
We only know what we believe. Now the best advice ever given to me was by a Rcrd Rep. "We have never had an oil related failure is you run the latest API rated oils that meat or exceed Fords recomendations, and change your oil on schedule."
Old Aug 11, 2003 | 02:51 PM
ken04's Avatar
ken04
Correct Oil for V10
It certainly won't hurt it, the early V-10's called for 10-30, and the newer called for 5-20, then Ford said ALL V-10's should use 5-20. But I've run 10-30 in my 98 thinking the thicker oil would be better in hotter weather, which is how it used to be. But modern oil technology is not the way it used to be. And thinner oil actually cools the engine better than the thicker oil, and in fact there's even a 0-20 out so viscosity no longer means better protection, as in the old days.
Old Aug 14, 2003 | 06:01 PM
Edmo's Avatar
Edmo
Correct Oil for V10
Wally World has Motorcraft 5W20 for $1.77/quart... You can also get the V-10's Motorcraft oil filter while you are there.
Cheap and easy...
Edmo
Old Aug 14, 2003 | 09:06 PM
Gary E K's Avatar
Gary E K
Correct Oil for V10
Now come on guy's, This time last year everyone said 5w30 was the oil to use, so that is what I used sence then, I got a 99- 250
and I use 5w30 every 3,000 without going a mile over. Just what oil should I use? Got 54k on her now. Thanks in advance.
Old Aug 18, 2003 | 07:33 PM
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
Correct Oil for V10
How cold does it get in San Antonio? I would stick with the 10w-30 if it is convienent for you to do so. I use Mobil 1 10w-30 in both my Excursion and F-250 CC SD with V-10 engines. The 10w-30 is probably more shear stable than 5w-30 in comparable oils.
Old Aug 18, 2003 | 09:52 PM
Gary E K's Avatar
Gary E K
Correct Oil for V10
I live in cen. Florida.
Old Aug 24, 2003 | 05:37 AM
brcowan's Avatar
brcowan
Correct Oil for V10
Okay guys, to add to the confusion; I was always told to run a heavier oil in a high mileage engine. My truck has almost 90k on it. What oil viscosity is recommended. (I also live in Florida, so no severe cold temps)
BTW, I have used Castrol for years with no problems. Any comments about Castrol oil?
Old Aug 25, 2003 | 08:35 AM
Big Orn's Avatar
Big Orn
Correct Oil for V10
I have 78K on mine and still run the 5W30 Castrol with no problems. That is my oil of choice, but there are many out there. Unless your engine holds low oil pressure and knocks and taps considerably, I would stick with the 5W30.
Old Aug 25, 2003 | 01:11 PM
Gary E K's Avatar
Gary E K
Correct Oil for V10
Sounds Good to me.
Thanks.
