Lumbar "Fix"
Old Nov 24, 2015 | 07:50 AM
finallyo3gt's Avatar
finallyo3gt
Lumbar "Fix"
I had the blown out lumbar. When I bought the truck, it had a seat cover with pillows shoved under it. I bought an inflatable on fleabay, and was using it outside the seat, but got tired of adjusting it. So, here is my fix:
Bought this somewhere in the internet. It has some padding, so it doesn't just go completely flat.
Tilt the seat all the way forward and you will see this clip. This u shaped clip is on the front of the seat cover.
This barbed strip is on the back of the seat cover and folds 180* over the u shaped clip, and then hooks into it.
I drilled and used metal screws to re-attach the brace, then used zip ties to support the inflatable pad, and hold the rods in place. My most redneck fix in a long time, but I was trying to be quick, more than proper
This and the metal brace fell out when I opened the seat cover.
Screwing the metal brace directly to the frame, took some arch out and made the upper lumbar a bit firm. It may work better to use some kind of joining bracket to keep the arch in the brace. Also the lower inflatable lumbar is a tad low. I'd have to play with it to work that out.
All in all, it's better than cushions flopping around, and is pretty comfy so far. OH... and coolest of all, I discovered the pump and relief valve still work, so the little hand pump ball went away, and I just used the trucks inflate/deflate tube.
Old Nov 24, 2015 | 01:34 PM
z31freakify's Avatar
z31freakify
I had mine removed when I had my seats done, if i would of known better
Old Nov 24, 2015 | 02:51 PM
fordman67's Avatar
fordman67
I just whip out the tig and reattach said bracket. Much better than screws
Old Nov 24, 2015 | 05:34 PM
finallyo3gt
show off..haha
Old Nov 24, 2015 | 08:02 PM
fordman67's Avatar
fordman67
Stick welded Kevin's in the campground at rre two years ago even lol.
Old Nov 24, 2015 | 08:26 PM
stainlessstroker95's Avatar
stainlessstroker95
That's a good idea for a replacement air bladder.
Old Nov 24, 2015 | 08:29 PM
finallyo3gt
I have a welder in the garage Never even bothered to wire the 220 for it. But that's a whole other story.
Old Nov 24, 2015 | 10:17 PM
fordman67's Avatar
fordman67
ahh mine is 110v but 140a @100%dc . i added the tig. it has always done what i asked. I have done a lot of frame work in the past and it has alway been good. Cant imagine not having a welder,use it a LOT!
either way,how does that bladder do? it looks kind of unsupported there.
wish there were replacement oe style bladders...but then I would need 4 lol
Old Nov 25, 2015 | 06:58 AM
finallyo3gt
I bought the gas enhanced wire feed welder, then discovered some issues with the house that put us in litigation, that will likely lead to us being out of the house, so I've lost all desire to make any upgrades, including my 240 plug.
It does ok. The support isn't really the issue, the position is kinda low. Usually I keep it pretty flat and sit with my butt near the back of the seat bottom. If I inflate it, it hit right at my belt line. So I usually just move my butt forward a bit if I feel the need to inflate it, and it works out. I've been in it up to 45 min so far and it's pretty comfy. It certainly could be set up better, but that was my 15 min. fix.
Uni Moe
15
Jun 24, 2016 07:13 PM
hasteranger
Dec 23, 2015 11:45 AM
f1barry
Jun 9, 2013 12:01 AM
raytasch
Nov 11, 2011 09:06 PM
add2255
Jul 27, 2010 07:51 AM
