Sponsored by: Auxito
1997 Computer change for diagnostics
Old Nov 29, 2015 | 10:52 AM
Bluegrass 7's Avatar
Bluegrass 7
Again, the crank sensor will not be cylinder specific unless a tooth on the timing wheel is bent or chipped off for that part of the crank rotation.
The crank sensor is the reference signal to the PCM for all functions that need a time reference except fuel injection that is done from the cam position sensor on the driver side head..
Crank sensor signal provides RPM/Tach feedback for idle control, Ignition timing, signals for the fuel pump operation and many other functions.
Did you notice the OX Sensor 'switching' for bank 1 is much lazier than bank 2?
Good luck.
Old Nov 29, 2015 | 11:32 AM
jeepnatv4life's Avatar
jeepnatv4life
the 2 data graphs I posted look pretty consistent with each other. The freeze switch was just when I caught it. For Bank 1 to be a miss shouldnt Bank 2 show a change where Bank 1 would stay the same/missing.
What are you thinking? Im stuck....
If it were mechanical miss it shouldnt be intermittent as this is and cutting the key off and turning it back on should still have the miss
Old Nov 29, 2015 | 12:23 PM
projectSHO89's Avatar
projectSHO89
Mode 6 i have no test 53 to id the cylinders
The first couple of years of OBDII it wasn't TID $53, it was TID $51, IIRC. You can check the applicable OBDII manual to check for certain. Those can be downloaded for free from Motorcraft Technical Resource
Old Nov 29, 2015 | 01:15 PM
jeepnatv4life
Thank you ill plug back up to the truck and look.
Old Nov 29, 2015 | 04:23 PM
drilldeep's Avatar
drilldeep
closely following this....very similar sounding to what i have going on aside from the fact that mine actually misses very hard. please let us know the details on what cures it!
Old Nov 29, 2015 | 06:15 PM
jeepnatv4life
Tomorrow at work im gonna look up wiring to the injector. Friend was saying somethin along the line of a ground or power feed to the injectors may be breaking down. Im gonna noid light #1 in comparison with others on the bank. Maybe ill find #1 is dimmer pointing towards a harness issue which would be why the other pcm changed nothing....
F150Dad
1997 - 2003 F150
May 23, 2018 02:08 PM
rob7676
1997 - 2003 F150
Aug 26, 2015 04:24 PM
Andrew7dg
1997 - 2003 F150
Dec 4, 2013 08:30 AM
Trevor.801
Jul 11, 2013 11:10 AM
graydonricker
1997 - 2003 F150
Sep 16, 2011 09:35 PM
