P0720 Engine Code
Old Nov 23, 2015 | 11:34 PM
jsjustice007's Avatar
jsjustice007
P0720 Engine Code
Hello,
The last few days I've started getting the Wrench Light on my dash panel upon starting the truck and trying to put it into gear. I first noticed this on a cold morning and got the wrench but the truck went into Reverse and once i got going I was only in 3rd gear. I started and stopped the engine a few times and finally got it going. Since then it seems to do it all the time whether hot or cold. Tonight i noticed that if i start the engine and just go directly into Drive I dont have the issue but if i ever go into Reverse it goes into limp mode and i get the big yellow wrench again. I only have engine Code P0720 which seems to refer to a speed sensor. Has anyone had any luck repairing with similar issues. I cant seem to find the sensor listed on the typical auto part websites.
Thanks,
Old Nov 24, 2015 | 11:44 AM
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by jsjustice007
...The last few days I've started getting the Wrench Light on my dash panel upon starting the truck and trying to put it into gear...
Welcome to the forum, jsjustice007! It sounds like it's time for a visit to your local Ford Dealership. What's your truck's model year/mileage? I'd like to look into some options to help out with the wrench light as well.
Crystal
Old Nov 24, 2015 | 11:54 AM
jsjustice007
Crystal
2011 F150 XLT
3.5 Ecoboost
238k miles
Upon startup I can go straight into drive without issue but anytime I go into reverse I get the wrench and have to cycle the ignition to clear the wrench to get back into normal drive mode instead of 3rd gear only.
Never had transmission issues at all. No shift issues or slippage. Seems like it has to be a sensor sense it came out of nowhere.
Old Nov 24, 2015 | 12:58 PM
FordService
Official Ford Rep
2011 F150 XLT
3.5 Ecoboost
238k miles
Thanks for the quick reply, jsjustice007! Since this can be easily reproduced, you may want to take your tech on a test drive and replicate it for them. Be sure to come back and tell us how things go.
Crystal
Old Nov 26, 2015 | 12:01 AM
lballard1129's Avatar
lballard1129
Could just pop in a VSS, look over the wiring and if it appears to be good than throw in that sensor. Doesn't sound like the transmission is grinding or slipping does it?
dclinton
May 28, 2021 03:54 AM
edsjr01
2004 - 2008 F150
Feb 13, 2019 05:44 PM
dragunbayne
Escape & Escape Hybrid
Jan 21, 2019 11:07 AM
loydoityourselfer
Jun 22, 2011 06:18 AM
Old93f150
Sep 17, 2010 08:43 PM
