SPX, Riffraff, Barder and others turbo wheel review thread
#31
Started to break mine down tonight and could not even get the v-clamp off the turbo for the downpipe. I ended up cutting out the exhaust and left the now bent bolt on the v-clamp in place and will cut it out tomorrow or Thursday. I have a new one on the way from RiffRaff already, so not a big deal.
I guess the 16 year old bolt that is mounted against the firewall and behind the turbo didn't want to budge. A precision dremel cutting bit will take care of it in no time though.
When I go to re-install the v-clamp I will be sure that the bolt is easily accessible and on top of the exhaust and not behind it where you cannot even see the bolt.
#32
on
I sprayed it with Blaster, made some "Use a Lifeline" texts to find out mostly how rough to be and if it was normal. After about 15mins, I grabbed a hammer and long screwdriver and as I was wedging the end of the screwdriver onto the end of the clamp opening, everything just popped loose and the clamp nearly flew off
Be sure to remove your intake boots and cover the openings with clean rags first. I had trouble getting the turbo to clear the spot and ended up breaking the EBPV solenoid
#33
#34
on
I hear ya, I soaked the bolt even though I couldn't see it behind the exhaust with penetrating oil, but it just would not budge. Luckily there is a break in the v-clamp section where it is just banding at the very top of the exhaust pipe so that allows for easy access with a Dremel.
I didn't have any better pics of it, sorry
#35
I think I have passed the point of no return. I bent the bolt trying to use a swivel attachment on an extension for the deep socket. With the strange angle, it being up against the firewall and out of sight and the fact that it hasn't moved in 16 years. I called it a night, ordered a new one from RR and came up with a plan to cut the v-clamp off tomorrow.
#37
#39
My theory is the impact to loosen the clamp has to drive the clamp outward, away from the mating surfaces. The angles of the turbo and downpipe are a wedge in the clamp; any pressure applied inward toward the wedge will increase the tension holding the clamp in place. Plus it's been there a looong time. Been a few years since I had mine off but I thought I removed the bolt and used a shortish pry bar and an improvised fulcrum, levered up away from the turbo and sproing!
Glad you guys are having this conversation since I have the same project coming up over the Christmas break. Last season's RiffRaff 6/6 wheel and Dorman uppies. Oooh, aaah.
#40
I ended up cutting the v-clamp off in about 2 minutes time tonight. I know it is hard to explain, but the way the bolt on the clamp was installed it was 100% out of sight and no combination of sockets, swivels or extensions was going to budge it loose. So, I dremeled it into submission between the actual v portions of the clamp and it popped right off.
I then took time to apply ATF/acetone to the up-pipe and turbo pedestal bolts for removal in the near future.
#42
#43
#45
As to throttle, seems to have more pickup, also no major whoosh wehn shifting at speed. Like that. Only have 12 miles on it, so I will need to wait to report. Does have a nicer whistle though :-)
