T 87 borg warner help
Old Nov 22, 2015 | 08:03 AM
rodtek's Avatar
rodtek
Hey guy's has anyone done this ? I would like to change my 3 speed t 87 top load column shift to a floor shift . Can you just change out the top cover ? Any help would be appreciated thanks Mike
Old Nov 22, 2015 | 09:25 AM
harleymsn's Avatar
harleymsn
If you have a Remote (column) shift, you do not have a top loader.
Old Nov 22, 2015 | 12:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Column shift top-loaders were used on mid-fifties trucks ('53 -on) with the HD T87D. Rodtek, need to include info on what year truck we're talking about.
I suspect you can just take the central shifter assembly, complete, from another T87 and swap them, but I don't know that for a fact.
Old Nov 24, 2015 | 04:38 PM
rodtek's Avatar
rodtek
Mine is in a 1970 ford brothers p 350 step van here are the numbers on the trans case t87g-1a top cover is t87-148f 6 bolt top load. I am about to find out ! I found one out of a 1949 f1 a t 87 hd top load floor shift so I am going to try it . Mine is just like the drawing you sent . I will let you know if it works. thanks for your reply
Old Nov 28, 2015 | 03:11 PM
rodtek's Avatar
rodtek
Yes!! it does work. I just finished installing the floor shift on the coulmn shift transmission, set right on and shifts perfect
Old May 31, 2020 | 11:12 AM
Darren K. Truel's Avatar
Darren K. Truel
Switch form column to floor on P350 1971 (Ice Cream Truck)
This is good news. So, I am wanting to do this as well. Do you have any advise from your experience on what to look for when I am searching for the correct parts/transmission to switch to the floor shift? Thanks!
STEVEN HENDEL
Oct 15, 2018 05:12 PM
rodtek
Nov 20, 2015 02:27 PM
51merc
Sep 22, 2007 06:18 AM
black89
Dec 29, 2006 08:40 AM
black89
Nov 20, 2006 06:24 AM
