Coolant fan
Old Nov 21, 2015 | 01:58 PM
billinspain's Avatar
billinspain
Coolant fan
Hi all, I have a 1998 Lincoln Navigator. Can anyone let me know if it is normal for the fan to start as soon as I start it up from cold. Have only had the vehicle for a few weeks and it has done this since I've had it, not sure if it is right or not. Any thoughts would be appreciated.
Old Nov 21, 2015 | 08:58 PM
pdqford's Avatar
pdqford
What fan are you referring to?
Old Nov 21, 2015 | 10:54 PM
Skauber's Avatar
Skauber
Isn't that a engine driven fan? That will spin as long as the engine is running, but the clutch will prevent it from spinning full speed.
Old Nov 22, 2015 | 02:04 AM
billinspain
There's me being economical with the truth again, sorry it is the large fan that cools the radiator.
Old Nov 22, 2015 | 10:16 AM
R&T Babich's Avatar
R&T Babich
Unless a previous owner replaced the engine cooling fan with an electric one yours probably came with a thermal clutch fan.
A thermal clutch fan will always spin at a slower speed until the temperature rises enough to cause the thermal clutch to engage and spin the fan faster.
The clutch normally will slip at higher RPM.
An engine doesn't need a fan above 35 mph.
A fan spinning at full speed when the car is moving faster can impede the air flow thru a radiator and wastes power.
http://www.haydenauto.com/upload/Hay...TS_6980012.pdf
Old Nov 22, 2015 | 10:46 AM
billinspain
I would say that it looks like the original fan with clutch. Part of the reason for posting was it seems to take a long time to warm up, and when I've had the OBD-11 plugged in at normal running temperature it is showing up at 55 degrees Celsius (aprox 131 degrees Fahrenheit) and that is as hot as it gets. Have tested the thermostat and is working fine, also the gauge in the car at normal running temperature always stays above the C but below the first mark on the gauge.
Old Nov 22, 2015 | 04:51 PM
pdqford's Avatar
pdqford
Could be the CTS (Coolant Temp Sensor) is fubar. Try and get an infared thermometer and shoot the thermostat housing. You wanna see ~195*.
Old Nov 23, 2015 | 06:57 AM
billinspain
Ok thanks I will try and pick one up and post back.
Old Nov 23, 2015 | 04:28 PM
alloro's Avatar
alloro
Ditto all that!
Rick94110
Aug 21, 2016 12:45 PM
72Truckin
27
Aug 28, 2015 11:20 AM
mpmccarthy
Jan 28, 2012 10:20 AM
lazerf250
19
Oct 20, 2007 11:40 AM
Albedo
3.8 & 4.2L V6
Dec 29, 2003 08:33 PM
