solenoid wiring?
Old Aug 6, 2003 | 09:01 AM
shane43028's Avatar
shane43028
solenoid wiring?
78b f150 351m need a wiring diagram or a pic of where wires go on the solinoid.tried the search thing to no avail. thanks
Old Aug 6, 2003 | 09:37 AM
dfisher1's Avatar
dfisher1
solenoid wiring?
Shane,
The solenoid wire is the blue with a red stripe.
It goes from the ignition to the neutral/safety switch which is on the shifter side of the tranny. Then it goes back up to the harness and over to the soleniod. If you have a two node solenoid, put it on the front stud. If your not sure about which stud to connect to, jump twelve volts to either one and see which one closes the solenoid.
KingFisher
Old Aug 6, 2003 | 10:03 AM
shane43028's Avatar
shane43028
solenoid wiring?
of course there is the positive cable to battery,and the one to the starter and the red/blue with a plug on end and a brown with a plug these i know where they go.i also have the fusible link wire.then there are 3 black wires in a group,a red wire,and a yellow wire that im not sure about.it ran yesterday before i undid it all guess i should have paid better attention
Old Aug 6, 2003 | 01:20 PM
shane43028's Avatar
shane43028
solenoid wiring?
anyone?????????????
Old Aug 6, 2003 | 01:36 PM
Mil1ion's Avatar
Mil1ion
solenoid wiring?
To the front large connection on the Solenoid.
The other wires:
The Big black one from the starter goes on the big solenoid stud at the back.
The two little ones Brown > Red/Blue go top the I Terminal & S terminal.
All the others go to the Big stud on the solenoid which goes to the battery post.
Old Aug 6, 2003 | 07:58 PM
shane43028's Avatar
shane43028
solenoid wiring?
thanks mil
