Strange Codes...
Old Nov 18, 2015 | 07:33 PM
Grems4ever's Avatar
Grems4ever
Strange Codes...
Evening all. I ran a KOER test on the 302 I recently installed in the truck and got some strange codes, some of which are because I botched the power steering & throttle tests, but I can't make heads or tails of the others. Here they are...
40(?), 10(?), 44(thermactor inoperative), 60(?), 77(user error), 208(?), 33(EGR not opening), 77(user error), 52(power steering switch open)
I know 10 is usually a place holder that I've seen before on the other system. Can anyone shed some light on the mystery codes?
Thanks!
Old Nov 18, 2015 | 07:47 PM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Did you run the truck to full operating temp before running the test?
Old Nov 18, 2015 | 07:54 PM
Grems4ever's Avatar
Grems4ever
Yes - I got it up to full temp before running the test.
I'm a little bit concerned about the ECM. The last time I started getting odd codes on an EEC-IV system the ECM was going bad on me...
Old Nov 18, 2015 | 08:54 PM
Bad Bad Leroy Brown
I believe the user error code can be from not blipping the throttle at the correct moment to test the MAP sensor...
But considering that there are NO codes that should end in zero, AND your are getting both two and three digit codes... ECM? You might try one of those code readers to eliminate human error from counting flashes.
plus, you could pull the ecm and just check the capacitors. Would only cost you time.
Old Nov 18, 2015 | 08:57 PM
Grems4ever's Avatar
Grems4ever
Since those were taken with a dedicated code reader it looks like checking the capacitors is definitely on the to-do list this weekend.
Old Nov 18, 2015 | 09:02 PM
rla2005's Avatar
rla2005
There is no way you will get two AND three digit codes. It's one OR the other. Something is seriously wrong if a code reader displayed both.
ottawaguy
Dec 30, 2008 09:18 PM
F16Driver
Sep 11, 2007 10:04 AM
dongreene
Feb 20, 2006 07:54 AM
bkampbel
Oct 7, 2005 04:53 PM
Jrock909
Nov 28, 2004 07:07 AM
