Headlight upgrade
Old Nov 18, 2015 | 08:58 AM
MikeB 88's Avatar
MikeB 88
Headlight upgrade
I do most of my driving at night to/from work. I'd like to upgrade the lighting of my headlights in order to see better. The headlights in my 2000 Ranger are stock, and I keep the lenses clean with no yellowing or dulling. What would/could be my best affordable options? Replace bulbs or replace the entire assembly?
Old Nov 18, 2015 | 11:59 AM
pawpaw's Avatar
pawpaw
Add fog lights if you don't have them.
Old Nov 18, 2015 | 07:12 PM
MikeB 88's Avatar
MikeB 88
Didn't think of that option. I'll look into that also.
Old Nov 18, 2015 | 07:23 PM
pawpaw's Avatar
pawpaw
Turning my fogs on makes a Big peripheral vision difference on both sides of the road.
You could likely get OEM ones with the dash switch & bezel from a salvage yard for a lot less than new hdw.
Old Nov 18, 2015 | 08:52 PM
Ford'05HG's Avatar
Ford'05HG
Go on amazon and look for new fixtures with clear lenses, and then throw a set of HIDs in it. You should be able to see a hundred miles with that setup. I'm doing the same and you can get it all done and to your door for $150 or less.
And like pawpaw mentioned, fog lights are great for wide visibility, especially with HIDs in them too. You could drive with HID fogs alone if it was legal.
Plus, HIDs outlast regular bulbs and use less energy.
Old Nov 19, 2015 | 08:00 AM
greenpus's Avatar
greenpus
You forgot to mention putting HID's in a non-HID light bucket is like totally illegal...
Old Nov 19, 2015 | 11:57 AM
Ford'05HG's Avatar
Ford'05HG
Oh.. Well.. I didn't know that but I also never had any issues with mine. Guess this is kinda like using heating oil in your diesel, just don't get caught.
Old Nov 19, 2015 | 01:37 PM
greenpus's Avatar
greenpus
I use these in my 2000. Good bulb(s)
*** <b>NEW</b>** Philips Xtreme Vision (XTV) 9003 XTP / H4 / HB2 60/55W Lamp
Old Nov 19, 2015 | 01:38 PM
greenpus's Avatar
greenpus
pretty much. Kind of like cutting your catalytic converter off too
Old Nov 20, 2015 | 01:56 AM
MikeB 88's Avatar
MikeB 88
I've been looking at some of the headlights that LMC Truck has. I like pawpaw's idea of adding fog lights. But in order for them to "look right" I'd have to change my bumper as it doesn't have cutouts for fog lights.
Old Nov 20, 2015 | 01:58 AM
MikeB 88's Avatar
MikeB 88
Those look pretty interesting.
Old Nov 20, 2015 | 02:08 AM
Danner717's Avatar
Danner717
Sylvania Silverstar Ultras. I put them in both of my trucks and they made a big difference. They're a lot brighter and whiter
Old Nov 20, 2015 | 08:40 AM
pawpaw's Avatar
pawpaw
We don't have to change the bumper itself, just the bolt on fascia below it, that has the openings for the fog lights, which you could also likely come by at a good salvage yard.
But to have the finished factory look in the cab, you'd have to change the center dash bezel, that holds the radio, heater controls, cigar lighter, 12 volt power point, for one that also has the fog light switch cut out.
Sounds like your more interested in a plug & play upgrade & new head lamps with a different color temperature & beam pattern may be all you want/need for your type night driving & you've not told us how most of that night drive cycle goes. Is it mostly high speed open country freeway, slower rural, city, or a mix????
I use the fogs any time I'm towing, as it gives me that extra side vision to see deer, ect, that might try & dart out in front of me & they do help when there is ground fog on the way to, or from the lake fishing.
The factory lamps let me see far enough down road at the speeds I run, the fogs just nicely fill in the side vision for a nice Wide view, so it doesn't seem like I'm looking down a long narrow light tunnel & I really like that.
Let us know what you do & how it goes.
Old Nov 20, 2015 | 08:51 AM
Supercab's Avatar
Supercab
Wink
X-2 SYLVANIA SILVERSTAR ULTRAS!!!!!!!!
I have them in my '03 Ranger and my '99 F350 Super Duty!!!
Old Nov 20, 2015 | 04:07 PM
MikeB 88's Avatar
MikeB 88
One of my headlights actually burned out last night. Stopped at Walmart on the way home and picked up a pair of these. We'll see how they work in a couple nights.
I do love the way fog lights light up the sides/shoulders of the road. I find them extremely helpful in my wife's Charger. I'm still going to look into changing the front of Ranger to make a factory look. I can always mount a switch under the dash for them.
My usuall route is 7 miles of highway and 2 miles of a forested street. This is the one I'm most worried about, as its time for the deer to come out and play along the road. I really don't want to hit another one. Fogs plus a brighter headlight will help a lot.
