Hate My Wheels
Old Nov 19, 2015 | 06:25 AM
PlayersZ28's Avatar
PlayersZ28
Originally Posted by rlanicek
[/FONT][/COLOR]
<s>Lay a straight edge across theback side of the tire</s><s>and measure from the straight edge to the mounting surface, then</s> measure from the straight edge to the outermost part of the innerwheel lip. <s>Subtract the 2nd number from the first</s> and you havebackspace. Now you need to wheel width to figure out offset which is therelation of the mounting surface to the centerline of the wheel (from lip tolip).
[/COLOR]Wouldn't this be more accurate?
Yes, but that requires a straight edge that fits lip to lip without resting on the tire or a wheel with no tire on it. Backspace numbers are in round fractions so accuracy to to 2 decimal places isn't needed. Eg: BS is 4.00, 4.25, 4.5, etc.
I used to have a performance shop and this was the quickest method I found to find out what a customer had on the vehicle to start with and then go from there. I always found BS to be easier to work with and explain to the customer than offset was. Lower BS, wheel moves out. Higher BS, wheel moves in.
Zach Crivelli
28
Sep 28, 2021 09:28 AM
tFord_usa
Aug 18, 2017 05:44 PM
MichiganHunter
2004 - 2008 F150
Jan 16, 2010 09:45 PM
78'fordtruckguy
Oct 6, 2007 01:54 PM
66camperspecial
Jun 28, 2002 04:34 PM
