Question to ask
Old Nov 17, 2015 | 01:17 AM
93F150&69Stang's Avatar
93F150&69Stang
Question to ask
Hi I just bought a 93 f 150 with the 5.0 4x4 and dual tanks a few weeks ago. My question is I just took the bed off to clean the frame and fix the spring mount that usually rust off but now my truck won't start. When I turn the key you can hear the pump but it won't crank it is some type of safety feature?
Old Nov 17, 2015 | 03:59 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Did you knock the neutral safety switch connnector loose from the transmission?
Old Nov 17, 2015 | 07:26 AM
subford's Avatar
subford
Does the starter relay on the fender make any noise at all when you turn the key to the start position?
Old Nov 17, 2015 | 07:42 AM
93F150&69Stang
I don't think I knocked the neutral safety switch off I'll have to check. It's a auto if that makes a difference. I didn't hear it making any noise I'll check today.
Old Nov 17, 2015 | 07:51 AM
subford's Avatar
subford
With no sound from the stater relay check fuse "J".
Old Nov 17, 2015 | 08:20 AM
93F150&69Stang
Thanks for the schematic. So I went to try and start the truck again and it started Any ideas
Old Nov 17, 2015 | 08:30 AM
subford's Avatar
subford
Maybe the stalk was not all the way in "P" or "N" for the NSS.
Old Nov 17, 2015 | 08:36 AM
93F150&69Stang
You might be right because I did push the gear shifter farther up. Thanks for the help guys
zhicks16
38
Dec 18, 2018 10:58 PM
Jarrett Campbell
13
Aug 3, 2018 10:00 PM
Steve in NC
Nov 4, 2014 09:47 PM
durbancic
May 10, 2008 11:52 AM
senic
Mar 17, 2005 01:39 AM
