Weird eletrical problems please help!!
Old Nov 23, 2015 | 02:27 PM
pat420swed's Avatar
pat420swed
So i was just online for two hours and i found a thread kn the other site that said if i have 12v at the ign side of the relay then i just need to ground the white terminal on the relay and it will turn on the glow plugs, so i did that and the relay clicked and hummed like it used when heating the plugs.
So does this mean i need a new controller? Should i just run a push button? I just replaced the controller last summer. Tho is it possible i coukd of fried it when i hot wired the truck? When i was running the power wire in there was quite a bit of power going on and off quickly and i think maybe could of fried the controller
Old Nov 24, 2015 | 03:51 AM
southern-old-bold's Avatar
southern-old-bold
power to GP'S?
Do you have a way (multimeter) of seeing if there is power to the gp's when the relay clicks as you short wire it? If not, pull a glow plug and see if it is heating.
Old Nov 24, 2015 | 04:34 AM
pat420swed's Avatar
pat420swed
Ya i had 9.5-10 volts on the gp side when i shorted it
Old Nov 29, 2015 | 12:20 PM
pat420swed's Avatar
pat420swed
I replaced the gp controller and she fired right up, thanks guys
Old Nov 30, 2015 | 11:47 PM
The_Josh_Bear's Avatar
The_Josh_Bear
Glad you go her back in shape!
(For once the glow plug controller *really was* the problem! Doesn't happen much...)
Metz12345
Jan 19, 2015 06:48 AM
BaconJosh
Dec 7, 2014 03:20 PM
mabc926
Oct 2, 2010 10:25 AM
swimlvr591
Aug 13, 2010 02:19 PM
beaver steve
Sep 19, 2009 12:36 PM
