4X4 Swap Build Log
***Mods if this is not okay by all means do what you need to.***
I will try to be as detailed as possible and post whenever I can, giving pros and cons, what was easy and what was difficult for if anyone else wants to go this route.
I have decided to swap my truck specifically because of sentimental reasons, and the fact that i cant find any 4x4 CC LB trucks in my area for a reasonable price, plus i like a challenge.
The route that I have decided to go was a coil sprung 05 f350 front end. It has 3.73 gearing so i will be showing the swap over to 4.10 as well. I bought the axle, with hubs in good condition, good calipers, a steering box, brand new sway bars and links, good shocks all for $800. My budget for the swap is $1600 so we will see how it goes. Below are some of the pictures of the progress on my swap so far:
A friend helped me get the axle and frame with his flatdeck:
<a href="http://s246.photobucket.com/user/Ra1N-Rabit_Killer/media/2_zpsqnreth8y.jpg.html" target="_blank"><img src="http://i246.photobucket.com/albums/gg109/Ra1N-Rabit_Killer/2_zpsqnreth8y.jpg" border="0" alt=" photo 2_zpsqnreth8y.jpg"/></a>
Closer Look:
<a href="http://s246.photobucket.com/user/Ra1N-Rabit_Killer/media/1_zpsw4zv4zjm.jpg.html" target="_blank"><img src="http://i246.photobucket.com/albums/gg109/Ra1N-Rabit_Killer/1_zpsw4zv4zjm.jpg" border="0" alt=" photo 1_zpsw4zv4zjm.jpg"/></a>
Axle stripped of brakes, steering, frame removed:
<a href="http://s246.photobucket.com/user/Ra1N-Rabit_Killer/media/6_zpsmmpvdvhl.jpg.html" target="_blank"><img src="http://i246.photobucket.com/albums/gg109/Ra1N-Rabit_Killer/6_zpsmmpvdvhl.jpg" border="0" alt=" photo 6_zpsmmpvdvhl.jpg"/></a>
Parts pile: sway bar, manual t-case, trans cross-member, shocks
<a href="http://s246.photobucket.com/user/Ra1N-Rabit_Killer/media/4_zpskhul9hb2.jpg.html" target="_blank"><img src="http://i246.photobucket.com/albums/gg109/Ra1N-Rabit_Killer/4_zpskhul9hb2.jpg" border="0" alt=" photo 4_zpskhul9hb2.jpg"/></a>
In the next stage i will have to pick up the grade 8 bolts for the radius arms and coil buckets, buy 17" rims and tires, and purchase new front rotors as the old ones were cracked.
Chime in with thoughts and advice.
Frank
As for today's update:
- got the coil buckets sanded down and painted up (will post finished pics when paint is dry)
- Have done a lot of research on re-gearing the axle. Unsure if i need a new carrier or not, perhaps some of you will know (the axle is 3.73, going to 4.10)
Still cant seem to find decent 17" rims to clear the bigger brakes, will post up when i buy them.
An interesting note on the coil buckets from before i stripped and painted them, the paint almost looks bubbled from heat. I suppose because they are close to the manifolds it would make sense. Perhaps ford should look into a heat-shield or better coating? If paint bubbles on our northern trucks the metal below will disappear very quick.
<a href="http://s1380.photobucket.com/user/murraymassey1/media/IMG_20151115_195455857_HDR_zpsccd2q6gd.jpg.html" target="_blank"><img src="http://i1380.photobucket.com/albums/ah172/murraymassey1/IMG_20151115_195455857_HDR_zpsccd2q6gd.jpg" border="0" alt=" photo IMG_20151115_195455857_HDR_zpsccd2q6gd.jpg"/></a>
Coil bucket condition prior to sanding and paint:
<a href="http://s1380.photobucket.com/user/murraymassey1/media/IMG_20151115_184551563_HDR_zpsxfpqrudv.jpg.html" target="_blank"><img src="http://i1380.photobucket.com/albums/ah172/murraymassey1/IMG_20151115_184551563_HDR_zpsxfpqrudv.jpg" border="0" alt=" photo IMG_20151115_184551563_HDR_zpsxfpqrudv.jpg"/></a>
Thanks for reading.
Thanks for reading.
Frank
I watched the entire two hours and it was worth every minute. Goes through bearing pre-loads, side bearing pre-load, setting and adjusting backlash etc etc.
