1965 Mercury M250 Build
#91
on
1 Post
We did some sanding tests on my F100 and we believe that the paint is original, so that is how Al painted the Mercury.
There seemed to be a layer of Wimbledon White underneath the Twilight Turquoise? I assumed that this was overspray or maybe the truck was painted Wimbledon White first? This seems like a big waste of paint!
On the Wimbledon White parts of the truck, both above and below the side trim clip holes, we saw no real evidence of the Twilight Turquoise colour.
#96
on
1 Post
I purchased my re-popped fenders from Dennis Carpenter via a local reseller and I bought my rad support from LMC Truck.
Al installed the rad support and tested the alignment of the hood to the front upper valance, the cowl and the front fenders. He wasn't happy with the fit of the driver's side fender to the cowl and the door, so he had to work on the fender a bit.
The stone deflector from my Mercury was bent and cut up in the middle, but the ends were in great shape. So Al spliced the ends of my Mercury stone deflector onto the middle of the stone deflector from my F100.
#97
on
1 Post
I was back at the bodyshop on Halloween 2015. Al was shooting various black parts earlier in the week.
Here are the inner apron shims, various nuts, bolts (poked through cardboard), washers, cover plates.
Here is one of the upper valance supports, horn, fuel tank upper mounting clips, and the hood latch.
Here are the front fender brackets and the rad support.
I read in a post that the back of the tank was not supposed to be painted, as was the case with the F100 fuel tank, but we painted both sides of the Mercury fuel tank anyway.
At this point, I think that Al had inserted the proper shims and the hood, cab, doors and box were aligned correctly.
The upper valance, stone deflector and the tailgate were all finished and in primer.
#99
on
1 Post
So I was really wanting to use the floor mat from my F100, even though I knew that it wouldn't be a perfect fit. My Mercury has a 4 speed and the F100 has a 3 speed, thus the transmission hump was lower on the Ford.
I started to pull the floor mat out, but it was really stuck in there? Turns out the PO put in a layer of roofing shingles instead of installing some new floor pans!
I also pulled out the F100 firewall cover, the paint underneath was not all that great. The F100 Custom Cab firewall cover is on the top, the M250 Standard Cab firewall cover is on the bottom.
Here is the M250 cover again:
Here is the F100 cover again:
#103
on
1 Post
So these are my 8 bolt 'innie' rims. I have no idea what truck they originally came from, but the PO ran them on his '65 or '66 F250.
The PO ran LT 245/75R16 tires, which seem too big and too wide.
Once I get these rims cleaned up and painted, I'll probably get a set of LT 235/85R16 tires. This appears to be the closest diameter of tire to my original 750-16's, just 45 mm (1.77 in) wider.
I see that Coker Tire does have some 750-16 "Classic Blackwall" radial tires, but they use a tube and I don't think that will work with my rims?
