Sponsored by: Real Truck
2011 f250 coil spring help
Old Nov 15, 2015 | 12:20 PM
powerstroker100's Avatar
powerstroker100
Going to hang a snow plow on my 2011 f250, it did not come with the plow prep package so I have been looking into swapping in the plow prep coil springs (6000lb rating).
Looking up the current springs on my front end the part # is 5C34-5310-AGB which is a 4400lb spring for a 5.4l. My truck is a early build 6/2010 I believe, but why do I have 5.4l springs on my 2011 6.2l? I thought 4x4 6.2l had no less than 5200lb springs in the front.
And are all the coil springs interchangeable from 2005-2016 superduties? so when I order my plow prep springs will 6.2l f250 springs fit when I have 5.4l f250 springs on currently?
Old Nov 18, 2015 | 05:44 AM
rjcorazza's Avatar
rjcorazza
Ford lists 4400 lb springs for some 2011 6.2l configurations. The particular part apparently is used for multiple applications. When I was researching front coils for my 2011 6.2l I ended up at an aftermarket truck spring company (SDTruckSprings.com ?), But you could just go to Ford and order the coils you want from 4400-6000. I opted to add airbags inside my 5600lb coils for plowing, which has worked out well.
Old Nov 20, 2015 | 04:58 PM
powerstroker100
RJ thanks for the response, I was checking some things out on sdtrucksprings.com also.
Is your 2011 an f350 or f250? if it is an f250 did you swap the 2" rear block to a taller 4" or f350 rear axle block?
I think I'm going to get the oem 6000lb coil, but my truck sits almost perfectly level now so I'm going to need to install a taller block in the rear.
Old Nov 21, 2015 | 05:48 PM
rjcorazza's Avatar
rjcorazza
It's an F250 with the camper package, which is identical rear suspension as an F350 - taller blocks, overload spring, and sway bar.
I don't know if 6000 lb springs will affect ride height much without the plow, but with 2" blocks on the rear that may be a consideration. FYI, my 7.5' Western plow at 800 lbs will lower the front about an inch with the 5600 lb coils and airbags deflated. Most importantly, the blue airbags look cool
Old Nov 22, 2015 | 07:28 AM
seville009's Avatar
seville009
That's correct - the heavier springs will not raise the truck; it will just help the sag when you have the plow on.
I put the 6,000 lb springs on my 2006 F350 finally a few years ago. I have a Western MVP with wings that would scrap on dips when just driving around. The heavier springs reduced the sag by maybe 1.5" to 2" when the plow is up.
I bought the springs from the Ford dealer and had someone install them.
Old Nov 22, 2015 | 08:51 AM
nojoke327's Avatar
nojoke327
My 08 snow plow prep 350 with the 5.4 and 5600# springs sat an inch higher then a stock 350.
Old Nov 25, 2015 | 05:58 PM
powerstroker100
If it will not raise ride hide then that's great news because I thought the 6k springs raised the front about an inch and really don't want to have to raise the rear of the truck to compensate
Reverend Jim
Jun 21, 2018 10:04 AM
rpolar
Mar 5, 2016 03:08 PM
ford1puller
Dec 15, 2009 02:36 PM
StrokiN&SmokiN
Aug 11, 2008 11:52 AM
fordman16b
Aug 17, 2005 10:00 PM
