Sponsored by: Real Truck
4x4 not working
Old Nov 14, 2015 | 03:40 PM
redneck23ms's Avatar
redneck23ms
4x4 not working
2000 f250 7.3
today i tried using the 4x4 and no light or anything. here is what i have tried so far.
swapped the relays and also swapped them with the towing relays with no change.
not getting any voltage to the t-case shift motor
at the selector switch testing between pins 2 and 3 there is 4.3 volts with switch in 2wd 2.4 volts at 4 high and 1.09 volts at 4 low.
any suggestions on where to go from here? it worked fine 3 days ago.
Old Nov 16, 2015 | 07:58 AM
redneck23ms
Bump. Anybody have any suggestions?
Old Nov 16, 2015 | 01:59 PM
redneck23ms
Found my problem. The plug on the sensor on the t-case had come unplugged. Creative use of zip ties and it's back going.
Sous
16
Jul 15, 2017 06:40 PM
jtsantes
2004 - 2008 F150
Jun 25, 2012 07:46 PM
tree_7474
Jan 15, 2011 05:08 PM
laka
Dec 9, 2008 09:42 PM
cowboylelle
Apr 12, 2008 06:36 AM
