03 Nav heating
Old Nov 14, 2015 | 04:25 AM
RDockery's Avatar
RDockery
03 Nav heating
I replaced my heater motor, thermostat and antifreeze and if I'm driving I get warm to Lukewarm heat. But if I stop and idle for to long, it gets cold. Any suggestions?
Old Nov 14, 2015 | 09:56 AM
alloro's Avatar
alloro
The heater core is air bound. Go for a drive on the highway and it should clear up. Make sure the fill bottle level is up before you go.
Old Nov 23, 2015 | 02:36 PM
RDockery's Avatar
RDockery
It does get warm once your driving but it cools off as soon as it sits and idles for a moment.
Old Nov 23, 2015 | 04:30 PM
alloro's Avatar
alloro
Do both heater hoses going into the fire wall get nice and burning hot?
Old Nov 24, 2015 | 07:10 AM
RDockery's Avatar
RDockery
The heater hose are cold, not even Lukewarm when the vehicle is idling.
Old Nov 25, 2015 | 07:22 AM
projectSHO89's Avatar
projectSHO89
You do not have sufficient coolant flow through the heater core.
Here are the usual suspects in order of probability:
1. Low coolant.
2. Air bubble in heater loop.
3. Defective or improperly installed thermostat.
4. Restriction or clog in the heater loop.
5. Faulty water pump.
6. Everything else.
Old Nov 26, 2015 | 10:56 AM
alloro's Avatar
alloro
Did you ever go for the drive down the highway that I suggested?
82fordowner
50
Nov 23, 2014 09:06 PM
fyrmnk1
Apr 16, 2013 05:13 PM
hood
Apr 21, 2007 08:52 PM
donaldson202
Aerostar
Mar 7, 2005 02:41 AM
bh2112
19
Jan 17, 2005 04:07 PM
