Halogen vs hid vs led
https://www.ford-trucks.com/forums/1...eadlights.html
Yes I have used that headlamp and the lighting was horrible even compared to my old factory oxidized lamps.
I took them off and even though a friend wanted to buy them from me because they undoubtedly look cool I refused, I busted them with a hammer and pitched them in the trash.
So what is wrong with them ? They beam patterns were crooked and uneven and the cutoff was vague at best with unacceptable bleed over. My experience tells me that the build quality was the problem and likely in the manufacture of the reflector either being shaped wrong or it wasn't designed for a HID. Also the ballast were not made by Phillips, they were clearly knock offs.
On the plus the light color was decent and they looked cool.
Highly recommend OEM housings for ruggedness and waterproof-ness!
I have an 01' with stock headlights, upgrade would be nice, but only if there is an actual "performance" gain...ie more "safe" light output.
Thanks!
Thanks!
As a side note my search for the Holly Grail in lighting stems from 20 years of desert racing at night in Baja, our last race truck had over $10,000 worth of lights on it and yet there always seems to be a situation that calls for more.
Anyhow, back to the excursion. I have tried several setups, and recently switched back to the original 2 piece design and went with the lamps from Doorman using a Phillips 9007 bulb.
I switched back to the 2 piece design hoping they would be made to a higher quality then the fashion brands and choose the Doorman units since they are made by VAIP who does make CAPA certified headlamps. Unfortunately i think they also make a second tier quality product and sell them to Doorman
Another lesson I guess. I will be installing another set soon.
I will be buying a set of 2005 one piece CAPA certified headlamps made by TYC from rockauto.
To make a point about your "performance gain" The performance gain I seek comes from a high quality reflector. High quality in both the materials and the manufacturing process. Installing a brighter bulb in a housing that doesn't properly focus it in a suitable pattern is a loosing endeavor. Having a bright light scattered all over the place doesn't help you or the people who's eyes it is shining in.
Besides my factory replacement type headlamps I also run several other lights to suit my needs.
The 3 round lights are HID that stay covered on the streets in the US.
They are just plain dangerous to oncoming traffic even a mile away. ( Cost about $350 each and that is actually a lower end light )
The 2 square lights look similar to the factory fog lights but are actually HID lights which I use on desolate roads. They are actually aimed a little closer in the my factory lights but completely illuminate the area. I turn them off at the first sight of oncoming headlights as They would be irritating to oncoming traffic but not dangerously so because of the angle. ( cost $600 for the pair )
The single light in the bumper is a 55 watt halogen that is very high quality that is aimed far down the right and slightly off the side of the road to spot wildlife in the bushes. I live in a rural area plagued with deer. Even though it isn't likely to affect oncoming traffic I still turn it off for oncoming traffic. ( cost $150 ea )
But the bigger threat are cows when driving at night in Baja, Most all of Baja is open range and the cows will come lay down in the road for its warmth at night.
I have actually seen the aftermath of excursion vs cow and everything died, people, cow and excursion.
Combine the cows and the undulating roads. ( they build roads nap of the earth rather then graded flat ) and it is a receipt for disaster. there are plenty of road side shrines to remind you.
Personally I went to one-piece housings, threw standard Phillips bulbs in 'em, and tossed some 9005 bulbs in the foglights. The 9005's (Chevy high-beam bulbs) work GREAT at throwing more light on the road with good reach, and since they're way down compared to the foglights I'm not blinding anyone with them down there. My ex-wife followed me when I picked up the Chevelle and had to drive it 38 miles at night on poorly lit roads, even without window tint in the Chevelle I wasn't getting my retinas seared from the fog's. Haven't had any issues with them overheating, popping fuses, cooking wiring, etc and they're jumped to turn on with the headlights automatically. Had them in for over two years, zero issues. Just another idea for getting some more safe light on the road and out of oncoming traffic's eyeballs.
I have a spare set of 2005 headlights that I am currently doing an HID retrofit on, and one of the reasons I upped the foglights is the cutoff in the housings. It'll keep the light out of oncoming traffics' eyeballs, however it also keeps the light from reaching street signs at night so you can't read the damn things.
I had HIDS in my 2005 when I purchased it but took them out after being flashed by most oncoming traffic.
I really would like true projectors but am not sure what components are needed.
KrazeeMatt- Could you post info/pics of your HID retrofits?
Rob
