Sponsored by: Real Truck
Leak inside cab (Water)
Old Nov 13, 2015 | 09:42 AM
GA_Boy's Avatar
GA_Boy
Angry Leak inside cab (Water)
Tried search to no avail.
F250, 7.3, 2001, Lariet
Water leaked on the passengers right foot when I started off. I don't know if it was rain water or condensation from the A/C.
NOTE--Not sure if this has anything to do with it but the truck was parked in back for a month or so and ANTS (not sure what kind) invaded the cab. First noticed on a trip to FL and the Wife sprayed them. Still have a few show up now and then.
Could they possibly have blocked the A/C condensation drain pipe?
Thanks, Marvin
Old Nov 13, 2015 | 09:59 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If it was water and you had the heater or the A/C going I would certainly check the drain. It is a bit hard to spot due to being above the leaf spring and behind the wheel well cover, but it is there.
If you cannot find it, you could pop the cover off the blower motor and remove the blades. Then you have access to the fins and could run a slow stream of water across them and see if the water is going into the cab or out the drain hole.
petrokiller
Aug 21, 2018 01:45 AM
4X4 IN REFUGIO
1983 - 2012 Ranger & B-Series
Jul 27, 2007 12:23 PM
ChaoticBaz
15
May 21, 2007 12:16 AM
Storm
Jan 16, 2007 07:52 AM
