Starter Bendix wont Disengage
Old Nov 12, 2015 | 05:28 PM
williameub's Avatar
williameub
I've just put a motor in this truck because the other one was locked up. Now, whenever the truck starts, the bendix stays engaged. Once you shut the truck off, the bendix retracts.
Truck got a brand new starter with the motor...
I figured the ign. switch in the column was hanging so I started the truck with the solenoid on the fender and the bendix was still engaged.
too much fiction between the flywheel and bendix??
Im stumped.
Old Nov 13, 2015 | 04:52 PM
Hussler's Avatar
Hussler
Low battery voltage can cause this. Are the batteries and connections in good shape?
Old Nov 13, 2015 | 06:40 PM
williameub's Avatar
williameub
New batteries, alt, starter. Finally figured it out.
Solenoid was wired wrong... The alt. Was powering the starter after the truck was started.
mOROTBREATH
18
Sep 24, 2013 07:01 PM
eatont9999
28
May 14, 2011 12:18 PM
BuckHammer
55
Jan 31, 2011 12:59 AM
gollygwagen
13
May 22, 2008 09:03 PM
LunaI
Jan 16, 2004 05:30 PM
