P0171
Old Nov 12, 2015 | 04:12 PM
maxtruck00's Avatar
maxtruck00
P0171
I have 2007 explorer with the 4.6 v8
Recently it started running horrible. Rough idle, drives badly, hesitation, etc.
check engine light is on, code P0171. I cannot find a vacuum leak, and i am pretty much at a loss.
Before it started running poorly i replaced the thermostat, and flushed the coolant. i am assuming this is a coincidence.
Thanks for any advise
Old Nov 12, 2015 | 09:22 PM
shorod's Avatar
shorod
You probably had the air intake tubing loose to replace the thermostat, correct? I'd start by confirming that all the intake air tubing between the MAF sensor and the throttle body is properly and securely installed. An air leak between the MAF and throttle body can result in the complaints you describe and would be pretty likely that you disturbed those during the work on the cooling system.
-Rod
Frdtrkrul
May 26, 2016 06:50 AM
deep101
Modular V8 (4.6L, 5.4L)
Feb 16, 2015 05:52 AM
Paul T
1983 - 2012 Ranger & B-Series
24
Dec 17, 2012 07:46 PM
Mike-11
Jan 10, 2011 11:04 AM
BK Mountaineer
Dec 3, 2009 08:20 PM
