Steering linkage idea
Old Nov 12, 2015 | 02:44 PM
Jarryd's Avatar
Jarryd
I've been reading up on a few things but this idea spawned from a conglomeration of everything I've found.
This will be a 6" lifted ttb half ton
I'd use 2wd f350 steering linkage and ream the holes out so I can run them on top instead of the bottom so I'll have a better angle.
Any reason this wouldn't work? I'm having a lot of issues with the stock stuff.
My other idea was to run a straight tie rod across but I figured that wouldn't work well with the IFS.
Old Nov 12, 2015 | 03:03 PM
Willz74's Avatar
Willz74
I see an issue with the steering arm attaching to the bar figure out how to flip over the tie rod at that end
You would need a tapered reamer
Do you have the diameter measure for the big end and small end of both that would be a good place to start
Old Nov 12, 2015 | 03:13 PM
Jarryd's Avatar
Jarryd
I can use the reamer to get the angle and to the tre flip. I found several write ups on this procedure on fsb and many were using the f350 components.
My other idea was to modify the spindle so I could use f350 d60 tie rod and drag link setup but I'm thinking that may not work with the flexing ttb. Though I've seen a similar setup on a Ranger or Explorer.
Old Nov 12, 2015 | 03:36 PM
Willz74's Avatar
Willz74
Are you trying to put the bar above the steering arm
Old Nov 12, 2015 | 03:52 PM
Jarryd's Avatar
Jarryd
Something like this is what I had in mind.
Well not exactly like that. I'd want the tie Rod to connect the two steering knuckles like what you'd see on a 78 truck.
Old Nov 12, 2015 | 04:05 PM
Willz74's Avatar
Willz74
You need to flip the tie rod over they should point the same direction you'll get binding issues otherwise
Old Nov 12, 2015 | 04:16 PM
Jarryd's Avatar
Jarryd
That's what I'm looking to accomplish here. I was going to do the standard end flip like I'm seeing done and then use f350 tie rods rather than the stock f150 ones so they'll be stronger.
nolfi
Mar 2, 2013 07:11 PM
P3aflyer
Mar 15, 2008 11:35 PM
hilltd69
Oct 19, 2007 10:01 AM
Brian794x4
18
Jul 22, 2005 10:04 PM
montster
Oct 3, 2003 10:03 PM
