Flooring over MC access cover...
I am going to venture to say I have the same, if not similar, brake MC from CPP. My question is, are you driving/braking your truck? I can't seem to get past "MUSHY" on my pedal.
Thoughts?
Paul
Go to Mid Fifty or any other Ford truck parts catalog store. Here is their link:
Search Results - Mid Fifty F-100 Parts
To get past mushy requires you to start at the beginning and pull all 4 wheels and check condition of the wheel cylinders and brake shoes and replace as necessary, (I actually replaced everything)replace the fluid and check the master cylinder and brake lines for leaks. Mushy brakes is more than likely a combination of several things, not just one thing.
Everything on my truck is brand new except the cab and frame. The whole brake system is new, with 4 wheel discs. Still mushy. Through process of elimination, Id have to say the machining in the CPP proportioning valve assembly is somewhat sloppy. I've heard of several others with the same problem. Fortunately, CPP is a very good company, and stands behind their products so I'm sure it'll get worked out before I drive it a long distance.
janedoe058
11-05-2006 08:45 AM
