Radiator drain plug leaking ?
Old Nov 10, 2015 | 07:58 PM
NICKSAN's Avatar
NICKSAN
1994 E150, club wagon, 5.8
I flushed radiator yesterday, got home today and found the radiator drain plug leaking. Its not the original radiator and I cannot find a pic online of what the plug looks like, they all look very different than mine.
Does anyone know what the thread size and pitch should be if there is a standard?
I cannot tighten it anymore without it snapping, Its plastic.
I really dont want to change the whole radiator just because of a cheap plastic drain plug.
Thanks.
Old Nov 10, 2015 | 08:08 PM
vettex2's Avatar
vettex2
maybe the o-ring fell off when you flushed it.
Old Nov 10, 2015 | 08:11 PM
NICKSAN's Avatar
NICKSAN
It was still on but it was kinda flattened a bit. I just want to plug it however I can.
Old Nov 10, 2015 | 10:21 PM
vettex2's Avatar
vettex2
reinstall it with orange silicone.
Old Nov 11, 2015 | 07:22 PM
NICKSAN's Avatar
NICKSAN
Yea, I thought about that but I dont want another leak in the future.
Does anyone know what the thread size is? 3/8 or could it be metric?
Old Nov 13, 2015 | 07:56 PM
NICKSAN's Avatar
NICKSAN
Found out that its a 12" x 20 thread but not NPT, its just straight threads.
Ended up buying an assortment of orings and installed the closest one in the package. Went on a test drive and it its holding. I also picked up a 12 x 20 steel bolt also, that is straight threads not NPT, looks like it might be a oil drain plug but if the plastic one fails I will have this one and another oring as a backup.
Old Nov 18, 2015 | 07:25 PM
wirelessengineer's Avatar
wirelessengineer
This is exactly why I never touch those stupid things. Too often, once you open them up, you can't get them closed again.
If I want to drain a radiator, I disconnect the lower radiator hose.
The last time I used one of those it took a bunch of penetrating oil and several hours of wiggling to get it back in.
Never again.
Old Nov 18, 2015 | 07:47 PM
NICKSAN's Avatar
NICKSAN
Yea, this radiator plug is some kind of proprietary thing. After looking at dozens of different plugs I didnt find one that would work. I found a steel plug that has the same 1/2 x 20 thead that will fit but it is a oil drain plug for another kind of vehicle, but it also needs an oring.
I drove on a pretty far trip the other day and the plug/oring is holding.
Old Nov 19, 2015 | 01:56 AM
vettex2's Avatar
vettex2
I forgot to say , use a new o-ring
Old Nov 19, 2015 | 08:25 AM
NICKSAN's Avatar
NICKSAN
I did, but I am not sure if the oring I used is rated for high temps or not.
Ill see how long it lasts.
Matt1966
Sep 8, 2018 02:52 PM
BCHauler
Modular V10 (6.8l)
Aug 19, 2012 10:48 PM
XBAJBUSX
Mar 10, 2010 11:34 AM
huntinzombie
May 11, 2008 01:56 PM
Foo_909
1997 - 2003 F150
Feb 28, 2004 03:56 PM
