Long tube headers?
Old Nov 9, 2015 | 10:33 AM
85idipower's Avatar
85idipower
Long tube headers?
I have had a bad exhaust leak for a while now and I found the source... A tumb sized hole in me headers... So I want to put long tubes on my truck but my question is will I have to get a new y pipe and converter set up or can I use the old one?
Old Nov 9, 2015 | 02:52 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Climb under your truck and look at your existing setup. (whatever it may be as you did not describe it). Now envision that long tube headers will likely exit farther down and back than what I assume to be your current setup. Now ask yourself if your existing Y pipe will bolt up. I would suspect no. Now go on to your cat. Is it a single, (stock) setup or something fabricated in the muffler shop? Can you see any way of attaching your header collectors to the cat inlet? Chances are, you can accommodate with a modified Y pipe, but again, I have no knowledge of what you currently have.
Old Nov 9, 2015 | 04:05 PM
andym's Avatar
andym
Long tube headers are illegal for street driven vehicles in all 50 states. If you have emissions testing now or will have it in the future, don't get long tubes.
Danielsm17
May 3, 2018 02:48 PM
Saber123316
24
Sep 10, 2010 11:08 AM
THE KING
1978 - 1996 Big Bronco
Aug 7, 2007 05:31 PM
hillbilly316
Exhaust Systems
Nov 18, 2005 10:58 PM
panteramatt
Exhaust Systems
Sep 13, 2003 03:14 AM
