Electrical pains
Old Nov 8, 2015 | 11:52 PM
dsbyrd918's Avatar
dsbyrd918
Electrical pains
My 1989 F250 has had problems electrical problems from the day I got it slowly sorting them out I came to a road block I had a voltage regulator go out and burn up a gauge cluster well ever since then the battery light is on but it charges 14.2 and on that note it has burned up 3 more clusters I'm so confused on this if anyone can help please do
Old Nov 9, 2015 | 12:47 AM
mudmagnet63's Avatar
mudmagnet63
ELECTRICAL GREMLINS SUCK:
If you are going through clusters I would look for a grounding issue.
Old Nov 9, 2015 | 06:37 AM
dsbyrd918's Avatar
dsbyrd918
I don't even know where to start any pointers
Old Nov 9, 2015 | 03:46 PM
southern-old-bold's Avatar
southern-old-bold
check all ground wire connections
Improve all connections from battery, starter, GP'S, solenoids, then move to the grounds under the dash, at fuses, cluster and rear harness. Something big may be grounding through your little systems. Look carefully for signs of heat.
tracks_II
Nov 4, 2019 08:48 PM
Fred Zahn
Oct 22, 2018 12:08 PM
Lloyd399
Jul 2, 2017 05:57 PM
TrailsEnd
Apr 13, 2009 12:40 PM
Glen Murphy
Sep 29, 2006 10:36 PM
